Ir para o conteúdo principal
Pillow Stuffing Replacement
Kylee Harman
Kylee Harman e 2 outros colaboradores
Última atualização em 13 de set de 2023
20 - 25 minutos
Moderado
Introdução
Ir para o passo 1
Pillows quickly wear out and can start to smell, and replacing them can get very expensive. One inexpensive and quick way to bring the life back to your pillow is to simply replace the stuffing. Pillow stuffing can be found at local craft stores, and even at some mass retailers like Walmart. This guide explains the process of replacing the stuffing of a pillow that does not have a zipper, explaining the process of opening up the pillow without damaging the fabric, and providing simple instructions on restitching the seam.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Pillow Stuffing Replacement, Stuffing: passo 1, imagem 1 %32
    • Measure the length and width of the pillow to determine how much stuffing is needed.
    • A standard sleeping pillow is 20"x26", and will require 2 lbs of polyester fiber fill.
  2. Pillow Stuffing Replacement: passo 2, imagem 1 %32
    • With the seam ripper, create a 4-6 inch opening in the pillow about 2 inches from the corner.
    • To use the seam ripper: cut one stitch at a time using the sharp end. The red tip should remain upwards.
  3. Pillow Stuffing Replacement: passo 3, imagem 1 %32 Pillow Stuffing Replacement: passo 3, imagem 2 %32
    • Remove the existing stuffing from the pillow.
  4. Pillow Stuffing Replacement: passo 4, imagem 1 %32 Pillow Stuffing Replacement: passo 4, imagem 2 %32 Pillow Stuffing Replacement: passo 4, imagem 3 %32
    • Place a tennis ball-sized amount of new stuffing firmly into the 3 intact corners of the pillow.
    • This will help open up and stabilize the shell of the pillow to ensure even distribution of the stuffing.
    • Continue adding stuffing to the pillow to desired stiffness.
    • To ensure a smooth and regular shaped pillow, gently pull at the stuffing until it is fluffy before placing it into the pillow.
  5. Pillow Stuffing Replacement: passo 5, imagem 1 %32 Pillow Stuffing Replacement: passo 5, imagem 2 %32
    • Use the scissors to cut a length of thread approximately 24 inches long.
    • A dark thread is used here to maximize visibility. Typically, the thread would be matched with the color of the fabric.
    • Thread the needle and slide it to the center of the length of thread.
    • Triple knot the two loose ends together.
  6. Pillow Stuffing Replacement: passo 6, imagem 1 %32 Pillow Stuffing Replacement: passo 6, imagem 2 %32 Pillow Stuffing Replacement: passo 6, imagem 3 %32
    • Start a ladder stitch from the inside of the pillow by pulling the thread through the folded seam, right behind the opening that you created.
    • Make a small stitch through side of the opening.
    • Make an identical stitch directly across from your first stitch, on the opposite side of the opening. Pull the thread taut to begin the new seam.
    • Repeat, alternating from one side to the other until you have reached the end of the opening.
    • Be sure to keep each new stitch on the folds of the original seam.
  7. Pillow Stuffing Replacement: passo 7, imagem 1 %32 Pillow Stuffing Replacement: passo 7, imagem 2 %32
    • To compete the ladder stitch and close the pillow, pierce the needle through both sides of the seam and slowly pull the thread through until a loop is created.
    • Feed the needle through the loop and pull the thread tight.
    • Repeat this once more to ensure that the pillow is closed tightly, and cut off any excess thread with the scissors.
Linha de Chegada
Gear Up For Future Repairs
Shop all
1Comentário do guia
Thanks for sharing. Informative post. Keep up the good work.
Hamptons Cushions
mitu seo - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 49
Ao todo: 3,421
