Philips Norelco MultiGroom 3100 Motor Replacement
Introdução
Ir para o passo 1This guide will teach you how to replace the motor and will require some soldering.
O que você precisa
Ferramentas
Exibir mais…
Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
Ferramenta utilizada neste passo:Tweezers$4.99
Use the tweezers to pull out the inner power button.
4 outras pessoas executaram este guia.
4Comentários do guia
¿Me puedes ayudar con algo?
Can you help me with something?
this guide was created also by nina lovekrist in 2015
Where can I get the motor with copper shaft?
