Pebble Steel Watch Band Replacement
Introdução
Ir para o passo 1Would you like to switch out the watch band on your Pebble Steel from leather to metal or vice versa? This guide will show you how.
O que você precisa
Ferramentas
Ferramenta utilizada neste passo:Flathead 1.5 mm Screwdriver$5.49
Place the watch on its side to expose the side pins.
Use a 1.5 mm flathead screwdriver to unscrew the pin that is holding the band.
3 outras pessoas executaram este guia.
1Comentário do guia
One of my Pebble Steel pins comes out just as expected, but the other just spins, and doesn’t come out. Any ideas?
