Ir para o conteúdo principal
Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement
David Hoyt
David Hoyt e 9 outros colaboradores
Última atualização em May 7, 2024
30 minutos
Moderado
Ferramentas incorretas
Introdução
Ir para o passo 1
Use this guide to replace the mainboard and navigation board in your Parrot AR.Drone 2.0.
AR.Drone 2.0 spare parts and mounting tools are available from several Parrot retailers.
O que você precisa
Ferramentas
Exibir mais…
Vídeo de Apresentação
  1. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement, Mainboard and Navigation Board: passo 1, imagem 1 %32
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 2, imagem 1 %32 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 2, imagem 2 %32
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 3, imagem 1 %32 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 3, imagem 2 %32
    • Turn the drone upside down.
    • The cover is held on by plastic tape. Peel off the tape and use a spudger to remove the back cover.
  4. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 4, imagem 1 %32 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 4, imagem 2 %32 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 4, imagem 3 %32
    • Using a spudger, separate the connector for the downward camera.
    • Remove the camera from the body by pulling it off the foam body.
  5. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 5, imagem 1 %32 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a spudger to release the black retaining clip. Then disconnect the connector to the sensors.
    • Use tweezers to carefully remove the ribbon from the connector.
    How can I get that connector, the one it’s disconnected?
    gui txr - Responder
  6. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 6, imagem 1 %32
    • Remove the four 8mm torx screws with a T6 bit.
    • Remove the four 8mm philips head screws with a PH00 bit.
  7. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 7, imagem 1 %32 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 7, imagem 2 %32
    • Carefully pull the secondary board from the mainboard.
  8. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 8, imagem 1 %32 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 8, imagem 2 %32 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 8, imagem 3 %32
    • Turn the drone right side up
    • Remove the USB connector from the battery retaining straps.
  9. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 9, imagem 1 %32
    • Release the rubber clip holding the USB and battery power cable to the body.
  10. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 10, imagem 1 %32 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 10, imagem 2 %32
    • Avoid using sharp tools near the battery.
    • Push the USB and power cable through the battery panel.
  11. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 11, imagem 1 %32 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 11, imagem 2 %32
    • Turn the drone upside down again.
    • Use a spudger to release the connector and carefully remove the ribbon.
  12. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 12, imagem 1 %32 Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 12, imagem 2 %32
    • Lift the mainboard up so that you can access the back.
    • Disconnect the first connector with the white wires using a nylon spudger.
    • Disconnect the second connector with the red and black wires using a spudger.
  13. Parrot AR.Drone 2.0 Mainboard and Navigation Board Replacement: passo 13, imagem 1 %32
    • The mainboard is now fully detached and can be removed.
Conclusão
4 outras pessoas executaram este guia.
David Hoyt
Membro desde: 04/09/10
4.053 Reputação
Autoria de 41 guias
Equipe
Cal Poly, Team 25-89, Amido Spring 2010 Membro de Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membros
Autoria de 61 guias
3 comentários
hey man, you make it too easy
ydebancangancity - Responder
Hi i am in need of the mainboard. I dnt know where i can buy 1. Any advice
Fugee Maoza - Responder
I WISH I knew if this would solve my drone issues. I am a disabled teacher & biologist. I was bought the AR drone 2.0 to help keep me in good spirit as I no longer had the strength 2 hold a dslr steady. My father set everything up and he had 1 successful flight. The second flight my dad again just wanted 2 do a simple flight and it just dropped out of the air from 5 feet into grass. IT HAS NEVER WORKED SINCE :( We tried the local hobby store where
I purchased got no help only wanting 2 sell new drones. We get a message saying "UNKNOWN ERROR" since 2013 or 14 I think i have tried everything that you tube says 2 check. : No broken crossbars, blades,gears etc. Resetting will get rid of warning then will not get more that 1ft off the ground and then goes where it wants once it even held its altitude.
So any help is gr8t. Don't have $ to waist with all medical care
Brett Cihlar - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 53
Ao todo: 6,951
