Ir para o conteúdo principal
Panasonic Toughbook CF-29 RAM Replacement
Devon Augustus
Devon Augustus e 6 outros colaboradores
Última atualização em July 21, 2019
5 minutos
Fácil
Fotos de ação
Introdução
Ir para o passo 1
This guide will show you how to add or replace the RAM in your Toughbook CF-29.
O que você precisa
Ferramentas
  1. Panasonic Toughbook CF-29 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 RAM Replacement: passo 2, imagem 1 %32 Panasonic Toughbook CF-29 RAM Replacement: passo 2, imagem 2 %32
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 RAM Replacement, RAM: passo 3, imagem 1 %32
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 RAM Replacement: passo 4, imagem 1 %32
    • Pull the clips aside to release and remove the RAM.
Conclusão
Devon Augustus
Membro desde: 04/12/10
130 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 27-93, Amido Spring 2010 Membro de Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Membros
Autoria de 26 guias
3Comentários do guia
Thanks for sharing this. I just bought a panasonic toughbook from http://buytough.com and I think this will come in handy. :)
Katie Sutton - Responder
there is another ram slot you failed to mention
sparkynaz - Responder
Pretty sure on the CF-29, you can extend the RAM by another 1 GB, which is nice
Joseph D'Aquila - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 21
Ao todo: 18,432
