PSP 300x Analog Stick Replacement
Introdução
Ir para o passo 1Guide for removing the Analog stick in a Sony PSP-3000
O que você precisa
Place the PSP face down and locate the battery cover on the left side of the device.
Lift and remove the battery cover to reveal the battery.
Remove the battery.
Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
Push the homebar to the right to release the tab located on the right side of the LCD screen.
22 outras pessoas executaram este guia.
2Comentários do guia
Thank you for the tutorial, and I learned a lot!
Thank you so much!!! you are the best!!!
