Ir para o conteúdo principal
PSP 2000  Memory Stick Slot Replacement
espinks
espinks e 8 outros colaboradores
Última atualização em August 30, 2020
10 - 25 minutos
Moderado
Introdução
Ir para o passo 1
Is your Memory Slot just not performing as well as it used to? Fix it!
O que você precisa
Ferramentas
  1. PSP 2000  Memory Stick Slot Replacement, Battery: passo 1, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement, Battery: passo 1, imagem 2 %32 PSP 2000  Memory Stick Slot Replacement, Battery: passo 1, imagem 3 %32
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000  Memory Stick Slot Replacement, Front Casing: passo 2, imagem 1 %32
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000  Memory Stick Slot Replacement: passo 3, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement: passo 3, imagem 2 %32
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000  Memory Stick Slot Replacement: passo 4, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement: passo 4, imagem 2 %32
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    Beware that some models of PSP 2000 (mine is a limited edition Crisis Core FF7 silver version, so I suppose it is related to it being a japanese PSP) have 2 minute TORX screws (T1? T2?) instead of the 2x 4mm Phillips pointed in orange around the USB port.
    Mighty Sashiman - Responder
  5. PSP 2000  Memory Stick Slot Replacement: passo 5, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement: passo 5, imagem 2 %32
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
  6. PSP 2000  Memory Stick Slot Replacement, Display: passo 6, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement, Display: passo 6, imagem 2 %32 PSP 2000  Memory Stick Slot Replacement, Display: passo 6, imagem 3 %32
    • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
    • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
    Theres a latch you have to pry on the other side of the console through the small hole in order to remove home menu bar
    Janus Golovka - Responder
  7. PSP 2000  Memory Stick Slot Replacement: passo 7, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement: passo 7, imagem 2 %32 PSP 2000  Memory Stick Slot Replacement: passo 7, imagem 3 %32
    • With the home bar out of the way, gently pry up the display using the opening tools.
    • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
    • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
    • Gently lift out the display.
    There are 2 ribbons connected to the screen. Both of them have to be disconnected in order to remove the screen.
    Ovismue Veholkin - Responder
    Do not lift the black tab on the thin cable. That's attached to the logic board.
    Colin Wack - Responder
  8. PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: passo 8, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: passo 8, imagem 2 %32 PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: passo 8, imagem 3 %32
    • Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
    • Slide off the left trigger along with the plastic bracket underneath.
    • Carefully pry off left trigger button using opening tools.
    • The button is adhered to the body. It can be re-adhered with hot glue after being pried-up, if necessary.
  9. PSP 2000  Memory Stick Slot Replacement: passo 9, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement: passo 9, imagem 2 %32
    • Use an opening tool to lift up the brown tab on the connector and remove the cable horizontally.
    • Gently remove the memory card slot by pulling it straight out.
    That's just removing the D-pad. The memory card slot is part of the main logic board.
    Yomcha Go - Responder
Conclusão
16 outras pessoas executaram este guia.
espinks
Membro desde: 10/18/09
3.642 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 6-3, Maness Fall 2009 Membro de Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Membros
Autoria de 37 guias
2 comentários
Thank you, i'am Zakaria Farid from Morocoo
swat4ever2015 - Responder
would this work for a 2001 model?
James Ginther - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 60
Últimos 30 dias: 301
Ao todo: 28,613
