Ir para o conteúdo principal
PSP 1000 Buttons Replacement
Henry Lee
Henry Lee e 8 outros colaboradores
Última atualização em 26 de set de 2024
15 minutos
Fácil
Introdução
Ir para o passo 1
The PSP's buttons may become jammed or may not function properly. This guide will show how to access the buttons for repair, cleaning, or replacement.
O que você precisa
Ferramentas
  1. PSP 1000 Buttons Replacement, Battery: passo 1, imagem 1 %32
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 Buttons Replacement: passo 2, imagem 1 %32 PSP 1000 Buttons Replacement: passo 2, imagem 2 %32
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
    You are dumbbb... BRO YOUR DUMB BC U DIDNT HAVE TO USE A TOOL TO OPEN THE DOOR. USE YOUR FINGER""
    Paulo Moments - Responder
    The battery door can be damaged dont use a tool
    That also happend to me it got destroyed by screwdriver
  3. PSP 1000 Buttons Replacement: passo 3, imagem 1 %32 PSP 1000 Buttons Replacement: passo 3, imagem 2 %32
    • Using your finger, remove the battery upwards from the system as shown.
    The use of the opening tool is completely unnecessary. There is a finger actuated opening latch button that says “PUSH” on it. Simply press down with your thumb then slide your thumb down and away, dragining the battery door with it. It will then come off. Assuming the system still has its original plastics, they may have become brittle enough that the opening tool could damage the release button or the plastic cover.
    Franklin Allen - Responder
  4. PSP 1000 Buttons Replacement, Front Casing: passo 4, imagem 1 %32 PSP 1000 Buttons Replacement, Front Casing: passo 4, imagem 2 %32
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
    Much luck to you if you have a tiny, metal screwdriver like I did, the screws might be stuck in there and may require some force.
    Squib - Responder
    you need to peel back the warranty sticker in order to access both the lower left and lower left screws
    Frederick zzstu Geib - Responder
    This is a bit misleading, you should only remove the two black screws in the battery compartment. The silver ones can stay.
    Damian Cartwright - Responder
    The two left hand screws won’t come out of mine
    XULF - Responder
    iFixit screwdriver bits aren't thin enough to reach the two screws on the right near the memory stick slot.
    Fliggle_Slaps - Responder
    Can't edit previous comment so here's a new one:
    Standard or older iFixit screwdriver bits aren't thin enough to reach the two screws on the right near the memory stick slot. You'll need precision bits that have longer tips to reach these deep screws.
  5. PSP 1000 Buttons Replacement: passo 5, imagem 1 %32
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 Buttons Replacement: passo 6, imagem 1 %32 PSP 1000 Buttons Replacement: passo 6, imagem 2 %32
    • Gently separate the outer plastic casing from the rest of the system as shown.
  7. PSP 1000 Buttons Replacement, Buttons: passo 7, imagem 1 %32 PSP 1000 Buttons Replacement, Buttons: passo 7, imagem 2 %32 PSP 1000 Buttons Replacement, Buttons: passo 7, imagem 3 %32
    • If the Arrow Buttons are not functioning properly, flip over the outer casing and locate the inside of the buttons, as shown
    • Carefully remove the black rubber backing off of the buttons.
    • Clean the inside of the rubber and the outside of the buttons with a cloth.
  8. PSP 1000 Buttons Replacement: passo 8, imagem 1 %32 PSP 1000 Buttons Replacement: passo 8, imagem 2 %32
    • If needed, replace the old buttons with a new set (which can be purchased from Sony or other electronics stores).
    • Carefully re-insert the buttons. This should not require excess force, as the buttons should fit if they are arranged correctly.
    • Gently re-apply the back rubber to the back of the buttons.
  9. PSP 1000 Buttons Replacement: passo 9, imagem 1 %32 PSP 1000 Buttons Replacement: passo 9, imagem 2 %32
    • If function buttons (x, square, circle, triangle) need to be replaced, find the corresponding black rubber backing on the inside of the casing.
    • Carefully remove the back rubber to expose the rear side of the buttons as shown. (This can be done using your hands.)
  10. PSP 1000 Buttons Replacement: passo 10, imagem 1 %32 PSP 1000 Buttons Replacement: passo 10, imagem 2 %32
    • Next, carefully clean the receiving end of the buttons on the motherboard (shown on picture) with a cloth.
    • If the buttons are clearly damaged, then they need to be replaced.
    • Add the new ones in the form, with the correct button order. (The correct button order has the Triangle on the top, Square on the right, Circle on the left, and X on the bottom).
    • Be very careful! The buttons only go in one way. If you have trouble fitting them in, rotate them in their given spots until they fit in easily. Do NOT force them. Forcing the buttons in may cause damage.
  11. PSP 1000 Buttons Replacement: passo 11, imagem 1 %32
    • Once buttons are correctly replaced, the back rubbers are fit back onto the buttons, refer back to Replacing the Housing to reattach the casing.
Conclusão
34 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Henry Lee
Membro desde: 01/14/10
866 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 5-6, Forte Winter 2010 Membro de Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 Membros
Autoria de 34 guias
13Comentários do guia
It's a helpful guide,thx
Zero Knight - Responder
Great guide. I highly Recomend this to anyone that needs to replace their PSP buttons
unashamed45 - Responder
Otimo guia recomendo.
richardmosman - Responder
use magnetised screwdriver i had a normal one and it was a pain in the ass to put those tiny little bastards back
Nagy Dániel - Responder
Thank you this was a great guide
BLAISE of BASH - Responder
I have a similar problem with my psp 3000. The X button does not work when it is pressed. I removed the casing, checked if there was dirt on the rubber padding and on the motherboard where the buttons sit and there is no dirt. What should I do now. I realy love my psp, but without the X button working I can not use it. Is this problem fixable?
Christopher - Responder
Christopher, if that’s the case then you probably need to replace the conductive rubber padding, as that’s the part that really gets all the wear. I don’t know where you would find a replacement rubber padding, but you might try eBay or Amazon.
Daniel Whalen - Responder
Hey Daniel, thanks for your responce. Im still not sure exactly what the probelm is myself so thanks for the insight. I have ordered a new flex cable to see if that’s the soultion. Could this be the problem, a broken flex cables?
I recently bought a psp 3000 and when I started to use it, in the software of the psp the “X” button is set as the back button and the “O” button is set to be the enter button. I reset the factory setting, it doesn’t go to “X” being enter and “O” being back. Anyone know how to fix this problem? Could the psp be fake?
Blank Blank - Responder
It must be the Japanese Model. I own two Japanese psps and O is always the enter button. X is the back button and triangle is usually the menu screen. Hope that helps!
Pickle Satan -
My issues is the joy stick and it doesn't show how to fix joystick
Freezing God - Responder
Como solucionar quando o aparelho começa a entrar sozinho para sair do jogo ?
Ale Xandão - Responder
I'm having a problem with the R trigger on my PSP 1003. Button doesn't do anything when pressed. Tried cleaning the pads with a diluted isopropyl solution but didn't have any luck. Anyone else having similar issues? I'm wondering whether I need to unplug and then reattach the ribbon cable that's connected to the R trigger?
Bert - Responder
Comentar
Visualizações:
Últimas 24 horas: 30
Últimos 7 dias: 176
Últimos 30 dias: 702
Ao todo: 92,991
