Ir para o conteúdo principal
Ozeri Pronto ZK14-S LCD Replacement
Oneika White
Oneika White e 2 outros colaboradores
Última atualização em January 20, 2025
20 minutos
Moderada
This guide explains how to expose the LCD screen of the Ozeri Pronto ZK14-S. The detachment of the LCD motherboard is necessary to reveal the actual screen.
O que você precisa
  1. Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: passo 1, imagem 1 %32 Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: passo 1, imagem 2 %32
    • Twist the plastic plate slowly to the left to pull it away.
  2. Ozeri Pronto ZK14-S LCD Replacement: passo 2, imagem 1 %32
    • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
    • The sticker does not need to be completely removed.
  3. Ozeri Pronto ZK14-S LCD Replacement: passo 3, imagem 1 %32
    • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
  4. Ozeri Pronto ZK14-S LCD Replacement: passo 4, imagem 1 %32 Ozeri Pronto ZK14-S LCD Replacement: passo 4, imagem 2 %32
    • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
  5. Ozeri Pronto ZK14-S LCD Replacement: passo 5, imagem 1 %32 Ozeri Pronto ZK14-S LCD Replacement: passo 5, imagem 2 %32
    • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
  6. Ozeri Pronto ZK14-S LCD Replacement: passo 6, imagem 1 %32
    • Turn the device over so the back panel is facing up.
  7. Ozeri Pronto ZK14-S LCD Replacement: passo 7, imagem 1 %32
    • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
  8. Ozeri Pronto ZK14-S LCD Replacement: passo 8, imagem 1 %32
    • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
  9. Ozeri Pronto ZK14-S LCD Replacement: passo 9, imagem 1 %32 Ozeri Pronto ZK14-S LCD Replacement: passo 9, imagem 2 %32
    • Pry apart the two panels to separate them from each other.
    • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
    • Be careful when separating the panels to avoid damaging the wires they are connected by.
  10. Ozeri Pronto ZK14-S LCD Replacement, LCD: passo 10, imagem 1 %32 Ozeri Pronto ZK14-S LCD Replacement, LCD: passo 10, imagem 2 %32
    Ferramenta utilizada neste passo:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Using the 2.0 Flathead screwdriver, remove the three 7.20 mm screw on the back of the center LCD motherboard.
  11. Ozeri Pronto ZK14-S LCD Replacement: passo 11, imagem 1 %32 Ozeri Pronto ZK14-S LCD Replacement: passo 11, imagem 2 %32 Ozeri Pronto ZK14-S LCD Replacement: passo 11, imagem 3 %32
    • Stand the center motherboard up to expose the LCD screen
    • Be careful when standing up the LCD motherboard to avoid damaging the wires it is connected to.
    • Remove the LCD screen.
Conclusão
3 outras pessoas executaram este guia.
Oneika White
Membro desde: 10/01/15
712 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-4, Leahy Fall 2015 Membro de USF Tampa, Team 1-4, Leahy Fall 2015
USFT-LEAHY-F15S1G4
Membros da 4
Autoria de 5 guias
Um comentário
I had a similar model, it was different to open but the LCD was showing all 8's, I just reset the same LCD and it worked like new.
Dennis Lima - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 649
