Ir para o conteúdo principal
Oster Blend-N-Go My Blend Blade Assembly Replacement
Paul Long
Paul Long e 3 outros colaboradores
Última atualização em November 30, 2015
5 minutos
Moderado
Introdução
Ir para o passo 1
Use this guide to replace your damaged Blade Assembly.
  1. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: passo 1, imagem 1 %32 Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: passo 1, imagem 2 %32
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blade Assembly Replacement: passo 2, imagem 1 %32 Oster Blend-N-Go My Blend Blade Assembly Replacement: passo 2, imagem 2 %32 Oster Blend-N-Go My Blend Blade Assembly Replacement: passo 2, imagem 3 %32
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blade Assembly: passo 3, imagem 1 %32
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
Conclusão
Uma outra pessoa concluiu este guia.
Paul Long
Membro desde: 08/27/15
710 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 12-6, Blackwell Fall 2015 Membro de USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
3 Membros
Autoria de 5 guias
2 comentários
I’m confused, these are the steps you have to go through every single time you use this blender to blend something. This isn’t really a “replacement” process here. If someone needs to repair a cracked blade assembly or buy a new one, how would they do that?
Alan M - Responder
This process is not helpful at all. I followed as instructed but the blade is not moving at all?! What is going on? Pls provide better HELP INSTRUCTIONS.
Fareda Edwards - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 32
Ao todo: 3,744
