Ir para o conteúdo principal
OnePlus 7T Screen Replacement
Selena
Selena e 6 outros colaboradores
Última atualização em June 21, 2024
10 - 20 minutos
Moderado
Guia colaborativo
Introdução
Ir para o passo 1
Use this guide to repair a broken or faulty display in your OnePlus 7T smartphone.
Before disassembling your device, be sure the battery is charged below 25%. If accidentally punctured or damaged, the battery can catch fire and/or explode; if discharged below 25%, the chances of fire/explosion is decreased. Be sure to power off the device before beginning the disassembly process.
Follow the iOpener Heating guide for instructions on using the iOpener.
O que você precisa
Peças
Ferramentas
Exibir mais…
Vídeo de Apresentação
  1. OnePlus 7T Screen Replacement, OnePlus 7T Screen Replacement: passo 1, imagem 1 %32 OnePlus 7T Screen Replacement, OnePlus 7T Screen Replacement: passo 1, imagem 2 %32 OnePlus 7T Screen Replacement, OnePlus 7T Screen Replacement: passo 1, imagem 3 %32
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. OnePlus 7T Screen Replacement: passo 2, imagem 1 %32 OnePlus 7T Screen Replacement: passo 2, imagem 2 %32
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
    • An iFixit iOpener, hairdryer, or hot plate can also be used to heat the edges. See the iOpener Heating guide for instructions on using the iOpener.
  3. OnePlus 7T Screen Replacement: passo 3, imagem 1 %32 OnePlus 7T Screen Replacement: passo 3, imagem 2 %32 OnePlus 7T Screen Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Plastic Cards
    $2.99
    • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
  4. OnePlus 7T Screen Replacement: passo 4, imagem 1 %32 OnePlus 7T Screen Replacement: passo 4, imagem 2 %32
    • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
  5. OnePlus 7T Screen Replacement: passo 5, imagem 1 %32 OnePlus 7T Screen Replacement: passo 5, imagem 2 %32 OnePlus 7T Screen Replacement: passo 5, imagem 3 %32
    • Remove the phone's back cover.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
  6. OnePlus 7T Screen Replacement: passo 6, imagem 1 %32
    • Use a Phillips screwdriver to remove the 11 screws from the plastic motherboard cover.
  7. OnePlus 7T Screen Replacement: passo 7, imagem 1 %32 OnePlus 7T Screen Replacement: passo 7, imagem 2 %32 OnePlus 7T Screen Replacement: passo 7, imagem 3 %32
    • Use a spudger to pry up the plastic motherboard cover.
    • Remove the plastic motherboard cover.
  8. OnePlus 7T Screen Replacement: passo 8, imagem 1 %32 OnePlus 7T Screen Replacement: passo 8, imagem 2 %32
    • Use the flat end of a spudger to disconnect all flex cables leading to the motherboard.
  9. OnePlus 7T Screen Replacement: passo 9, imagem 1 %32 OnePlus 7T Screen Replacement: passo 9, imagem 2 %32 OnePlus 7T Screen Replacement: passo 9, imagem 3 %32
    • Grasp the red battery tab with your fingers.
    • Pull upwards on the tab and remove the battery.
  10. OnePlus 7T Screen Replacement: passo 10, imagem 1 %32 OnePlus 7T Screen Replacement: passo 10, imagem 2 %32 OnePlus 7T Screen Replacement: passo 10, imagem 3 %32
    • Use a pair of tweezers to grasp the end of the flex cables that were just disconnected.
    • Gently pull the cables backwards so that they remain bent back from the phone's motherboard area.
  11. OnePlus 7T Screen Replacement: passo 11, imagem 1 %32 OnePlus 7T Screen Replacement: passo 11, imagem 2 %32
    • Use a heat gun to lightly heat the edges of the phone's screen to soften the adhesive that connects the display to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges. Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges. Follow the iOpener Heating guide for instructions on using the iOpener.
  12. OnePlus 7T Screen Replacement: passo 12, imagem 1 %32 OnePlus 7T Screen Replacement: passo 12, imagem 2 %32 OnePlus 7T Screen Replacement: passo 12, imagem 3 %32
    • Apply a suction cup to the lower portion of the phone's display and pull firmly to create a crack between the screen and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the phone's display.
  13. OnePlus 7T Screen Replacement: passo 13, imagem 1 %32 OnePlus 7T Screen Replacement: passo 13, imagem 2 %32
    • Carefully remove the phone's display.
    • A flex cable is still attached to the back of the phone's display. Make sure the cable does not become caught when removing the display.
    Great tutorial. I wonder about the liquid damage resistance. Maybe the manufacturer applies a glue sticker around the edge or similar as happens with Apple iPhones.
    Antonio Salazar - Responder
Conclusão
Selena
Membro desde: 12/15/19
2.767 Reputação
Autoria de 14 guias
1Comentário do guia
There needs to be steps on how to reseal the device after the replacement.
Asd - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 39
Últimos 30 dias: 167
Ao todo: 11,577
