Ir para o conteúdo principal
Nvidia Shield Controller Buttons Replacement
Daniel Eberhart
Daniel Eberhart e 6 outros colaboradores
Última atualização em 22 de jan de 2024
20 minutos
Fácil
Introdução
Ir para o passo 1
This guide help you replace your Nvidia Shield Portable buttons if they are faulty or broken. If the buttons on your controller are faulty or broken it is important to replace those buttons as they can interfere with the controllers ability to receive the users inputs (button presses).
Before starting the guide make sure to have a clean work area to disassemble the controller and that you have the replacement buttons.
Feel free to use any replacement parts you are most comfortable with and fit the Nvidia Shield Portable controller.
O que você precisa
Ferramentas
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. Nvidia Shield Controller Buttons Replacement, Remove Front Panel: passo 1, imagem 1 %32 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: passo 1, imagem 2 %32 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: passo 1, imagem 3 %32
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    For the rubber screw covers, it is easiest to push at them at the top, otherwise you have the possibility of damaging the surrounding rubber.
    Any hints at getting the center plastic screw cover out?
    Miles Raymond - Responder
  2. Nvidia Shield Controller Buttons Replacement, Remove Green Grill: passo 2, imagem 1 %32 Nvidia Shield Controller Buttons Replacement, Remove Green Grill: passo 2, imagem 2 %32
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: passo 3, imagem 1 %32 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: passo 3, imagem 2 %32 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: passo 3, imagem 3 %32
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Controller Buttons Replacement, Remove Battery Apparatus: passo 4, imagem 1 %32
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Controller Buttons Replacement, Removing Button Board: passo 5, imagem 1 %32 Nvidia Shield Controller Buttons Replacement, Removing Button Board: passo 5, imagem 2 %32 Nvidia Shield Controller Buttons Replacement, Removing Button Board: passo 5, imagem 3 %32
    • Remove seven 6.5 mm T5 torx screws from the button board.
    • Refer to the second image as some screws are not visible in the first image. One of these screws is covered by the orange ribbon.
    • Remove the button board.
Conclusão
7 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Daniel Eberhart
Membro desde: 09/22/14
379 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-1, Hickman Fall 2014 Membro de USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Membros
Autoria de 18 guias
2Comentários do guia
From where can I get the buttons?
Chirag Khatri - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 27
Ao todo: 6,293
