Ir para o conteúdo principal
Numark N4 Audio Jack Replacement
Erik Charlton
Erik Charlton e 2 outros colaboradores
Última atualização em March 15, 2023
25 - 35 minutos
Muito difícil
Introdução
Ir para o passo 1
This guide shows how to replace the audio jack without needing to replace the entire motherboard it is attached to.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Numark N4 Audio Jack Replacement, Numark N4 Disassembly: passo 1, imagem 1 %32
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
  2. Numark N4 Audio Jack Replacement: passo 2, imagem 1 %32
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
  3. Numark N4 Audio Jack Replacement: passo 3, imagem 1 %32
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
  4. Numark N4 Audio Jack Replacement: passo 4, imagem 1 %32
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
  5. Numark N4 Audio Jack Replacement: passo 5, imagem 1 %32
    • Using your fingers, gently unplug the yellow and red cable as pictured.
  6. Numark N4 Audio Jack Replacement: passo 6, imagem 1 %32
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
  7. Numark N4 Audio Jack Replacement, Audio Jack: passo 7, imagem 1 %32
    • Turn the panel around so that the audio jack is facing forward as shown.
  8. Numark N4 Audio Jack Replacement: passo 8, imagem 1 %32
    • Using a soldering station, carefully desolder the connection points around the audio jack and remove it.
    • To review soldering safety and techniques, please visit Como soldar e dessoldar contatos.
Conclusão
Erik Charlton
Membro desde: 10/10/17
843 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S13-G11, Cagle Fall 2017 Membro de USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 Membros
Autoria de 12 guias
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 689
