Ir para o conteúdo principal
Nobis NB09 Battery Replacement
Jackson McAdams
Jackson McAdams e 7 outros colaboradores
Última atualização em June 30, 2021
30 minutos - 1 hora
Moderado
Fotos de ação
Faltando Passos
Despedaçar
Introdução
Ir para o passo 1
This guide will show you how to replace the battery in an Android Nobis NB09 tablet.
Some possible symptoms which could show that your tablet's battery is dying include:
  • Battery is at a low percentage even after a fresh charge.
  • The tablet dies when it still has a lot of battery life.
  • The tablet becomes hot after using for a short period of time.
If you experience any of these symptoms, then it is likely the culprit is a failing battery.
O que você precisa
Ferramentas
Exibir mais…
  1. Nobis NB09 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Before beginning this process, make sure the device is powered off.
    • Remove the screws holding the case together.
  2. Nobis NB09 Battery Replacement: passo 2, imagem 1 %32 Nobis NB09 Battery Replacement: passo 2, imagem 2 %32 Nobis NB09 Battery Replacement: passo 2, imagem 3 %32
    • Use an opening tool to loosen and pry off the pink back plate.
  3. Nobis NB09 Battery Replacement: passo 3, imagem 1 %32 Nobis NB09 Battery Replacement: passo 3, imagem 2 %32
    • Remove the black electronic tape covering the circuit board.
  4. Nobis NB09 Battery Replacement: passo 4, imagem 1 %32
    • Use the soldering iron to remove the black and red wires from the circuit board.
    • The black wire is the ground and the red wire is the battery positive terminal.
    • To reassemble, use the soldering iron to solder the leads at the end of the black (-) and red (+) wires from the new battery onto the proper terminals on the circuit board.
  5. Nobis NB09 Battery Replacement: passo 5, imagem 1 %32 Nobis NB09 Battery Replacement: passo 5, imagem 2 %32
    • Gently loosen the adhesive under the battery to avoid damaging it.
    • Use caution; the battery is soft and will bend very easily.
    • Dispose of the old battery properly at an electronic waste center or verified battery recycling store.
    • When reassembling, apply adhesive to the back of the new battery.
Conclusão
3 outras pessoas executaram este guia.
Jackson McAdams
Membro desde: 04/01/15
390 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 7-1, Cichon Spring 2015 Membro de UMass Dartmouth, Team 7-1, Cichon Spring 2015
UMASSD-CICHON-S15S7G1
4 Membros
Autoria de 12 guias
1Comentário do guia
where can i buy a battery from
Frederick Shipman - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Ao todo: 3,023
