Ir para o conteúdo principal
Nintendo Switch Lite Digitizer Replacement
O que você precisa
  1. Nintendo Switch Lite Digitizer Replacement, Remove the back panel screws: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
    Pergunte ao FixBot
    Comentar
  2. Nintendo Switch Lite Digitizer Replacement, Remove the top and bottom back panel screws: passo 2, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Remove the top and bottom back panel screws: passo 2, imagem 2 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
    Pergunte ao FixBot
    Comentar
  3. Nintendo Switch Lite Digitizer Replacement, Release the clips securing the back panel: passo 3, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Release the clips securing the back panel: passo 3, imagem 2 %32
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
    Pergunte ao FixBot
    Comentar
  4. Nintendo Switch Lite Digitizer Replacement, Continue releasing the clips around the device: passo 4, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Continue releasing the clips around the device: passo 4, imagem 2 %32
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
    Pergunte ao FixBot
    Comentar
  5. Nintendo Switch Lite Digitizer Replacement, Twist to release the clips: passo 5, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Twist to release the clips: passo 5, imagem 2 %32
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
    Pergunte ao FixBot
    Comentar
  6. Nintendo Switch Lite Digitizer Replacement, Slide and pry around the corners: passo 6, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Slide and pry around the corners: passo 6, imagem 2 %32
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
    Pergunte ao FixBot
    Comentar
  7. Nintendo Switch Lite Digitizer Replacement: passo 7, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 7, imagem 2 %32
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
    Pergunte ao FixBot
    Comentar
  8. Nintendo Switch Lite Digitizer Replacement, Remove the back panel: passo 8, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Remove the back panel: passo 8, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement, Remove the back panel: passo 8, imagem 3 %32
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
    Pergunte ao FixBot
    Comentar
  9. Nintendo Switch Lite Digitizer Replacement, Remove the shield plate: passo 9, imagem 1 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the four screws securing the shield plate:
    • Three 3.1 mm screws
    • One 4.5 mm screw
    Pergunte ao FixBot
    Comentar
  10. Nintendo Switch Lite Digitizer Replacement: passo 10, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 10, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 10, imagem 3 %32
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
    Pergunte ao FixBot
    Comentar
  11. Nintendo Switch Lite Digitizer Replacement, Disconnect the interconnect cable: passo 11, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Disconnect the interconnect cable: passo 11, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  12. Nintendo Switch Lite Digitizer Replacement: passo 12, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 12, imagem 2 %32
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
    Pergunte ao FixBot
    Comentar
  13. Nintendo Switch Lite Digitizer Replacement, Disconnect the battery: passo 13, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Disconnect the battery: passo 13, imagem 2 %32
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    • During reassembly, wait until after you connect the interconnect cable (above) before connecting the battery.
    Pergunte ao FixBot
    Comentar
  14. Nintendo Switch Lite Digitizer Replacement, Remove the heat sink: passo 14, imagem 1 %32
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    Pergunte ao FixBot
    Comentar
  15. Nintendo Switch Lite Digitizer Replacement: passo 15, imagem 1 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    Pergunte ao FixBot
    Comentar
  16. Nintendo Switch Lite Digitizer Replacement: passo 16, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 16, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 16, imagem 3 %32
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    Pergunte ao FixBot
    Comentar
  17. Nintendo Switch Lite Digitizer Replacement, Remove the game card reader and headphone jack: passo 17, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Remove the game card reader and headphone jack: passo 17, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the game card reader cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  18. Nintendo Switch Lite Digitizer Replacement: passo 18, imagem 1 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the seven 3.1 mm screws securing the game card reader and headphone jack.
    Pergunte ao FixBot
    Comentar
  19. Nintendo Switch Lite Digitizer Replacement: passo 19, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 19, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 19, imagem 3 %32
    • Use a pair of tweezers or your fingers to carefully lift the game card reader and maneuver it to the left to slide the cable out of its connector.
    • Remove the game card reader and headphone jack.
    Pergunte ao FixBot
    Comentar
  20. Nintendo Switch Lite Digitizer Replacement, Remove the right trigger button assembly: passo 20, imagem 1 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
    Pergunte ao FixBot
    Comentar
  21. Nintendo Switch Lite Digitizer Replacement: passo 21, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 21, imagem 2 %32
    • Remove the right trigger button assembly.
    Pergunte ao FixBot
    Comentar
  22. Nintendo Switch Lite Digitizer Replacement: passo 22, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 22, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
    Pergunte ao FixBot
    Comentar
  23. Nintendo Switch Lite Digitizer Replacement, Disconnect the antenna cables: passo 23, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Disconnect the antenna cables: passo 23, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement, Disconnect the antenna cables: passo 23, imagem 3 %32
    • Use the point of a spudger to pry the black antenna cable coaxial connector straight up off its socket on the motherboard.
    • Repeat the same process for the white antenna cable.
    Pergunte ao FixBot
    Comentar
  24. Nintendo Switch Lite Digitizer Replacement, Disconnect the fan cable: passo 24, imagem 1 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  25. Nintendo Switch Lite Digitizer Replacement: passo 25, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 25, imagem 2 %32
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
    Pergunte ao FixBot
    Comentar
  26. Nintendo Switch Lite Digitizer Replacement, Disconnect the screen cable: passo 26, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Disconnect the screen cable: passo 26, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  27. Nintendo Switch Lite Digitizer Replacement: passo 27, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 27, imagem 2 %32
    • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
    Pergunte ao FixBot
    Comentar
  28. Nintendo Switch Lite Digitizer Replacement, Disconnect the digitizer cable: passo 28, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Disconnect the digitizer cable: passo 28, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  29. Nintendo Switch Lite Digitizer Replacement: passo 29, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 29, imagem 2 %32
    • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
    Pergunte ao FixBot
    Comentar
  30. Nintendo Switch Lite Digitizer Replacement, Disconnect the right joystick cable: passo 30, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Disconnect the right joystick cable: passo 30, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  31. Nintendo Switch Lite Digitizer Replacement: passo 31, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 31, imagem 2 %32
    • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
    Pergunte ao FixBot
    Comentar
  32. Nintendo Switch Lite Digitizer Replacement, Remove the motherboard assembly: passo 32, imagem 1 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the following six screws securing the motherboard:
    • Three 4.5 mm screws
    Pergunte ao FixBot
    Comentar
  33. Nintendo Switch Lite Digitizer Replacement: passo 33, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 33, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 33, imagem 3 %32
    • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
    • Remove the motherboard assembly.
    Pergunte ao FixBot
    Comentar
  34. Nintendo Switch Lite Digitizer Replacement, Remove the right joystick: passo 34, imagem 1 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the two 3.5 mm screws securing the joystick.
    Pergunte ao FixBot
    Comentar
  35. Nintendo Switch Lite Digitizer Replacement: passo 35, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 35, imagem 2 %32
    • Use your fingers to remove the joystick.
    • There is a thin black gasket around the hole where the joystick pokes through the frame. Try not to disturb this gasket as you remove the joystick.
    Pergunte ao FixBot
    Comentar
  36. Nintendo Switch Lite Digitizer Replacement, Remove the left speaker module: passo 36, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Remove the left speaker module: passo 36, imagem 2 %32
    • Use a pair of tweezers or your fingers to pull the left speaker cable straight up and out of its socket on the daughterboard.
    • Do not pull from the wires, or else you risk ripping the wires off the connector.
    Pergunte ao FixBot
    Comentar
  37. Nintendo Switch Lite Digitizer Replacement: passo 37, imagem 1 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the 4.5 mm screw securing the left speaker module.
    Pergunte ao FixBot
    Comentar
  38. Nintendo Switch Lite Digitizer Replacement: passo 38, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 38, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 38, imagem 3 %32
    • Use your fingers to lift the speaker module up and out of its recess to remove it.
    • Part of the speaker module sits underneath a delicate ribbon cable. Take care not to snag the speaker module on the cable as you remove it.
    Pergunte ao FixBot
    Comentar
  39. Nintendo Switch Lite Digitizer Replacement, Disconnect the motherboard interconnect cable: passo 39, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Disconnect the motherboard interconnect cable: passo 39, imagem 2 %32
    Pergunte ao FixBot
    Comentar
  40. Nintendo Switch Lite Digitizer Replacement: passo 40, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 40, imagem 2 %32
    • Use a pair of tweezers to slide the motherboard interconnect cable out of its connector on the daughterboard.
    Pergunte ao FixBot
    Comentar
  41. Nintendo Switch Lite Digitizer Replacement, Disconnect the screen and volume button cables: passo 41, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Disconnect the screen and volume button cables: passo 41, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flaps on the two ribbon cable ZIF connectors.
    Pergunte ao FixBot
    Comentar
  42. Nintendo Switch Lite Digitizer Replacement: passo 42, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 42, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 42, imagem 3 %32
    • Use a pair of tweezers to slide the daughterboard screen cable out of its connector on the motherboard.
    • Repeat this procedure for the volume buttons cable.
    Pergunte ao FixBot
    Comentar
  43. Nintendo Switch Lite Digitizer Replacement, Remove the volume buttons: passo 43, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Remove the volume buttons: passo 43, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the volume buttons.
    Pergunte ao FixBot
    Comentar
  44. Nintendo Switch Lite Digitizer Replacement, Disconnect the joystick cable: passo 44, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Disconnect the joystick cable: passo 44, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the left joystick cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  45. Nintendo Switch Lite Digitizer Replacement: passo 45, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 45, imagem 2 %32
    • Use a pair of tweezers to slide the left joystick cable out of its connector on the daughterboard.
    Pergunte ao FixBot
    Comentar
  46. Nintendo Switch Lite Digitizer Replacement, Remove the left trigger button assembly: passo 46, imagem 1 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the two 4.5 mm screws securing the left trigger button assembly.
    Pergunte ao FixBot
    Comentar
  47. Nintendo Switch Lite Digitizer Replacement: passo 47, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 47, imagem 2 %32
    • Remove the left trigger button assembly.
    Pergunte ao FixBot
    Comentar
  48. Nintendo Switch Lite Digitizer Replacement, Remove the daughterboard: passo 48, imagem 1 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the following four screws:
    • Two 4.5 mm screws
    • Two 6 mm screws
    Pergunte ao FixBot
    Comentar
  49. Nintendo Switch Lite Digitizer Replacement: passo 49, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 49, imagem 2 %32
    • Use your fingers to lift the daughterboard up and out of its recess to remove it.
    Pergunte ao FixBot
    Comentar
  50. Nintendo Switch Lite Digitizer Replacement, Remove the left joystick: passo 50, imagem 1 %32
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the two 3.5 mm screws securing the left joystick.
    Pergunte ao FixBot
    Comentar
  51. Nintendo Switch Lite Digitizer Replacement: passo 51, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 51, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 51, imagem 3 %32
    • Use the flat end of a spudger to lift the joystick up and out of its recess.
    Pergunte ao FixBot
    Comentar
  52. Nintendo Switch Lite Digitizer Replacement, Remove the midframe assembly: passo 52, imagem 1 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 2.5 mm screws
    • One 6 mm screw
    Pergunte ao FixBot
    Comentar
  53. Nintendo Switch Lite Digitizer Replacement: passo 53, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 53, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 53, imagem 3 %32
    • Use a spudger or your fingers to lift the midframe assembly up and out of its recess.
    • Remove the midframe assembly.
    Pergunte ao FixBot
    Comentar
  54. Nintendo Switch Lite Digitizer Replacement, Remove the buttons: passo 54, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement, Remove the buttons: passo 54, imagem 2 %32
    • At this point in the repair, remove all of the buttons if you haven't done so already, to prevent them from falling out and getting lost.
    • Use these two photos for reference.
    Pergunte ao FixBot
    Comentar
  55. Nintendo Switch Lite Digitizer Replacement, Remove the LCD: passo 55, imagem 1 %32
    • Heat an iOpener and apply it to the back side of the LCD along the top edge for 2 minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the LCD if you plan on reusing it, as it's susceptible to heat damage.
    Pergunte ao FixBot
    Comentar
  56. Nintendo Switch Lite Digitizer Replacement: passo 56, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 56, imagem 2 %32
    • Insert an opening pick between the frame and the top edge of the LCD to begin separating the two components.
    • Make sure to insert the pick completely under the LCD panel so you don't split and damage it.
    • You'll know you're splitting the panel if the silver backing bubbles and separates from the white lining.
    Pergunte ao FixBot
    Comentar
  57. Nintendo Switch Lite Digitizer Replacement: passo 57, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 57, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 57, imagem 3 %32
    • Slide the opening pick along the top edge of the LCD to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  58. Nintendo Switch Lite Digitizer Replacement: passo 58, imagem 1 %32
    • Apply a heated iOpener to the back side of the LCD along the right edge for 2 minutes.
    Pergunte ao FixBot
    Comentar
  59. Nintendo Switch Lite Digitizer Replacement: passo 59, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 59, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 59, imagem 3 %32
    • Continue sliding the opening pick around the right edge of the LCD, slicing the adhesive.
    • The LCD and digitizer cables are placed in a way to prevent them from easily snagging on the opening pick, but still use caution when sliding the opening pick along the gap.
    Pergunte ao FixBot
    Comentar
  60. Nintendo Switch Lite Digitizer Replacement: passo 60, imagem 1 %32
    • Apply a heated iOpener to the back side of the LCD along the bottom edge for 2 minutes.
    Pergunte ao FixBot
    Comentar
  61. Nintendo Switch Lite Digitizer Replacement: passo 61, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 61, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 61, imagem 3 %32
    • Continue sliding the opening pick along the bottom edge of the LCD to slice the adhesive.
    • You'll need to remove and reinsert the opening pick at various points along the LCD's edge to work around the frame.
    Pergunte ao FixBot
    Comentar
  62. Nintendo Switch Lite Digitizer Replacement: passo 62, imagem 1 %32
    • Apply a heated iOpener to the back side of the LCD along the left edge for 2 minutes.
    Pergunte ao FixBot
    Comentar
  63. Nintendo Switch Lite Digitizer Replacement: passo 63, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 63, imagem 2 %32
    • Continue sliding the opening pick along the left edge of the LCD to slice the adhesive.
    • Take care not to snag the LCD's daughterboard cable on the opening pick.
    Pergunte ao FixBot
    Comentar
  64. Nintendo Switch Lite Digitizer Replacement: passo 64, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 64, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 64, imagem 3 %32
    • Use the flat end of a spudger or your fingers to lift the LCD up and out of the frame to remove it.
    • If you're reusing the LCD (or your new LCD does not come with pre‑installed adhesive), follow this guide to install pre-cut adhesive around the perimeter before reassembly.
    Pergunte ao FixBot
    Comentar
  65. Nintendo Switch Lite Digitizer Replacement: passo 65, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 65, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 65, imagem 3 %32
    Microfiber Cleaning Cloths
    $3.99
    • If you're also replacing the digitizer, you can skip this step.
    • Use the flat end of a spudger to scrape off the remaining adhesive around the perimeter of the digitizer.
    • Prior to installing a new LCD, use isopropyl alcohol and a microfiber cloth to clean and remove any residual adhesive from the back side of the digitizer. Wait several minutes for any remaining alcohol to evaporate before installing the LCD.
    Pergunte ao FixBot
    Comentar
  66. Nintendo Switch Lite Digitizer Replacement, Remove the digitizer: passo 66, imagem 1 %32
    • Apply a heated iOpener to the front side of the digitizer along the left edge 2 minutes.
    Pergunte ao FixBot
    Comentar
  67. Nintendo Switch Lite Digitizer Replacement: passo 67, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 67, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 67, imagem 3 %32
    • Slightly bend the left side of the frame to create a gap between the digitizer and the frame.
    • Insert an opening pick into the gap.
    • If you're having difficulty creating a gap, apply more heat.
    Pergunte ao FixBot
    Comentar
  68. Nintendo Switch Lite Digitizer Replacement: passo 68, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 68, imagem 2 %32
    • Slide the opening pick along the left edge of the digitizer to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  69. Nintendo Switch Lite Digitizer Replacement: passo 69, imagem 1 %32
    • Apply a heated iOpener to the front side of the digitizer along the top edge for 2 minutes.
    Pergunte ao FixBot
    Comentar
  70. Nintendo Switch Lite Digitizer Replacement: passo 70, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 70, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 70, imagem 3 %32
    • Continue working the opening pick around the top-left edge of the digitizer to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  71. Nintendo Switch Lite Digitizer Replacement: passo 71, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 71, imagem 2 %32
    • Slide the opening pick along the top edge of the digitizer to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  72. Nintendo Switch Lite Digitizer Replacement: passo 72, imagem 1 %32
    • Apply a heated iOpener to the front side of the digitizer along the bottom edge for 2 minutes.
    Pergunte ao FixBot
    Comentar
  73. Nintendo Switch Lite Digitizer Replacement: passo 73, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 73, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 73, imagem 3 %32
    • Continue working the opening pick around the bottom-left edge of the digitizer to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  74. Nintendo Switch Lite Digitizer Replacement: passo 74, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 74, imagem 2 %32
    • Slide the opening pick along the bottom edge of the digitizer to slice the adhesive.
    Pergunte ao FixBot
    Comentar
  75. Nintendo Switch Lite Digitizer Replacement: passo 75, imagem 1 %32
    • Apply a heated iOpener to the front side of the digitizer along the right edge for 2 minutes.
    Pergunte ao FixBot
    Comentar
  76. Nintendo Switch Lite Digitizer Replacement: passo 76, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 76, imagem 2 %32 Nintendo Switch Lite Digitizer Replacement: passo 76, imagem 3 %32
    • Use your hands to slowly lift the left side of the digitizer, opening it like a book.
    • The positioning of the digitizer cables prevents removing the digitizer straight off the frame.
    Pergunte ao FixBot
    Comentar
  77. Nintendo Switch Lite Digitizer Replacement: passo 77, imagem 1 %32 Nintendo Switch Lite Digitizer Replacement: passo 77, imagem 2 %32
    • Lift the right side of the digitizer straight off the frame at a 45-degree angle to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
24 outras pessoas executaram este guia.
Craig Lloyd
Membro desde: 02/10/16
42.897 Reputação
Autoria de 82 guias
4Comentários do guia
Great guide, but quick tip when removing the screen. There are two pieces of the screen sandwiched together and when I took mine apart, these two pieces came unstuck and ruined the screen itself. The digitizer was fine, but the LCD came apart. So make sure the opening pick gets under both of these parts rather than just the reflective back.
Bridger Caicedo - Responder Compartilhar
I bought this Switch Lite with a broken LCD to repair and sell, so the screen was already blown out, but I had the same issue. The LCD was still connected to the digitizer and it actually peeled the LCD apart. As I said earlier, the LCD was already broke so it wasn’t a big issue, but I would of been fairly angry if it hadn’t of been.
Matthew D. H. - Responder Compartilhar
it looks like it might be possible to do steps 1 - 10, then step 28, then steps 66 onwards, and reverse to reassemble, the guide isn’t clear why it would be required to do a full tear down, is there something that would make this method not work or more likely to cause further damage, if I’m just switching out the digitizer, pun intended.. :) ?
Johnmichael Quinlan - Responder Compartilhar
Were I to guess, I would say that the full teardown guide is meant to apply to any, and all, scenarios, regardless of any unmentioned issues that a user may have.
Another possibility is that if a user has a damaged digitizer from a drop, or other type of impact(s); then by performing a full teardown, they may discover other elements in need of repair.
Jeff Blankenship Jr. - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 28
Últimos 7 dias: 203
Últimos 30 dias: 978
Ao todo: 55,963
