Ir para o conteúdo principal
Nintendo DS Main Circuit Board Replacement
kingdesmond
kingdesmond e 18 outros colaboradores
Última atualização em 9 de jun de 2024
10 - 15 minutos
Moderado
Introdução
Ir para o passo 1
This is a guide that teaches how to replace a Nintendo DS motherboard also known as a circuit board.
The Nintendo DS is a video game console released by Nintendo proposing two screens working in tandem with wireless connectivity, and an integrated microphone.
The main circuit board holds and makes all communication between components of the device possible. Therefore, whenever the communication between the functioning components takes longer than expected or there is no communication, replacing the motherboard is a necessity.
The removal of the main motherboard of the DS is essential to access the screens and to replace other imperatives.
The replacement could be done in 10 simple steps.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Nintendo DS Main Circuit Board Replacement, Battery: passo 1, imagem 1 %32 Nintendo DS Main Circuit Board Replacement, Battery: passo 1, imagem 2 %32 Nintendo DS Main Circuit Board Replacement, Battery: passo 1, imagem 3 %32
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Nintendo DS Main Circuit Board Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Nintendo DS Main Circuit Board Replacement: passo 3, imagem 1 %32
    • Remove the battery from the Nintendo DS.
  4. Nintendo DS Main Circuit Board Replacement, Back Panel: passo 4, imagem 1 %32
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
    I am currently doing this after my DS broke, and I just cannot get the screws out. My dad thinks they are too big, and I see they are stripped. Am I screwed?
    Theo Skar - Responder
    Hi @theoskar, Sorry to hear you're having a hard time removing the screws from your DS. We put together a quick guide and video with a few tips you can try here. Stripped screws often happen when the tool doesn’t quite match the job, but the good news is that they’re easy to prevent with the right technique. If you haven’t already, take a look at our guide on screwdriver technique. We hope this helps!
    Sarah Westberg -
  5. Nintendo DS Main Circuit Board Replacement: passo 5, imagem 1 %32 Nintendo DS Main Circuit Board Replacement: passo 5, imagem 2 %32 Nintendo DS Main Circuit Board Replacement: passo 5, imagem 3 %32
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
    If some of your screws spin free but can’t be removed, it maybe that the screw posts have separated from the shell.
    This makes separating the back panel more difficult, but it will still work.
    The plastic used for the original silver nds may be the most prone to the UV damage that causes the plastic to become brittle.
    Del Riordan - Responder
  6. Nintendo DS Main Circuit Board Replacement, Motherboard replacement.: passo 6, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
  7. Nintendo DS Main Circuit Board Replacement: passo 7, imagem 1 %32 Nintendo DS Main Circuit Board Replacement: passo 7, imagem 2 %32 Nintendo DS Main Circuit Board Replacement: passo 7, imagem 3 %32
    • Unlock the two large ribbon cables by moving the black clip up.
    • Carefully pull the ribbon cables down and out with your fingers.
    • Do not use pliers to pull the cables, as they can be damaged easily.
    Benutze für die nächsten Schritte besser einen Spudger und keine Pinzette,
    sonst läufst du Gefahr eines der Kabel oder die Platine selbst zu beschädigen.
    Better use a Spudger, not a Tweezer for the next Steps.
    That minimize the risk to demolish one of the wires or the mainboard himself.
    Christian - Responder
    That’s what i did but it didn’t work
    TrequanBlake - Responder
    I can’t get the cables out, how do I do it?
    Are you able to flip open the black latch, or is that the part that's stuck?
    Gena FM -
    Hi Theo, you might find this guide on how to recognize and disconnect cable connectors helpful.
    Sarah Westberg -
  8. Nintendo DS Main Circuit Board Replacement: passo 8, imagem 1 %32 Nintendo DS Main Circuit Board Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
    • Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • It may be useful to use tweezers to remove the small ribbon cables.
    • Be careful not to damage the delicate ribbon cables.
    Does anyone know where I can get a new connector for the P6 connector? I can only find them for the ds lite
    Matthew Leto - Responder
    "Slide the locks for the small ribbon cables down to the side, and remove the cables." Could mention that you are pushing them from the right to the left/towards where the cables are coming from. To the side sounds like towards the right edge
    M Beck - Responder
  9. Nintendo DS Main Circuit Board Replacement: passo 9, imagem 1 %32 Nintendo DS Main Circuit Board Replacement: passo 9, imagem 2 %32
    • Locate the Wifi antenna pigtail connector.
    • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
  10. Nintendo DS Main Circuit Board Replacement: passo 10, imagem 1 %32
    • Feed the ribbon cables through the opening on the board.
    • Pull up and remove the circuit board, and set it aside.
    Where's 11 and 12
    Lucy - Responder
Conclusão
22 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
kingdesmond
Membro desde: 10/27/09
2.150 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-3, Maness Fall 2009 Membro de Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Membros
Autoria de 31 guias
1Comentário do guia
This was really helpful. Thank you!
Jess Anderson - Responder
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 42
Últimos 30 dias: 263
Ao todo: 31,023
