Ninja Master Prep QB900B button replacement
Introdução
Ir para o passo 1This guide will teach you how to replace the spring in the button of your blender.
O que você precisa
Pull out the highlighted spring.
Now wash the button with soap and water, and follow the guide backwards to reassemble.
Any idea where to get a replacement switch for this model? Mine is FRIED! Thank you!
2Comentários do guia
mine has different screws and they won’t come out easily. looks like it might have a star head. thought it was hex and now the screws are stripped :(
turns out it was a security torx. how annoying.
