Ir para o conteúdo principal
Nikon D5200 Screen Replacement
Alexander Corn
Alexander Corn e 5 outros colaboradores
Última atualização em 7 de mai de 2024
20 minutos
Moderado
Introdução
Ir para o passo 1
Make sure to have your soldering iron ready prior to replacing the screen. This will make the process go faster as the time it takes to heat the soldering iron varies.
O que você precisa
Ferramentas
Exibir mais…
  1. Nikon D5200 Screen Replacement, Screen: passo 1, imagem 1 %32 Nikon D5200 Screen Replacement, Screen: passo 1, imagem 2 %32 Nikon D5200 Screen Replacement, Screen: passo 1, imagem 3 %32
    • Fully open the LCD panel so that its screws are easily accessible.
    • Remove the two 2.5 mm screws from the outside edge of the screen casing, and the two 3.5 mm screws from the inside edge.
  2. Nikon D5200 Screen Replacement: passo 2, imagem 1 %32 Nikon D5200 Screen Replacement: passo 2, imagem 2 %32 Nikon D5200 Screen Replacement: passo 2, imagem 3 %32
    • Pry open the plastic casing using the opening tool or by hand.
  3. Nikon D5200 Screen Replacement: passo 3, imagem 1 %32 Nikon D5200 Screen Replacement: passo 3, imagem 2 %32 Nikon D5200 Screen Replacement: passo 3, imagem 3 %32
    • Use the plastic opening tool to pop up the latch holding the ribbon cable on the right side of the circuit board, and remove it.
    • Use the plastic opening tool to pry the ribbon cable on the left side of the circuit board up and off of its socket.
  4. Nikon D5200 Screen Replacement: passo 4, imagem 1 %32 Nikon D5200 Screen Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, unplug the smaller cable.
  5. Nikon D5200 Screen Replacement: passo 5, imagem 1 %32 Nikon D5200 Screen Replacement: passo 5, imagem 2 %32
    • Desolder the three small wires on the left side of the circuit board.
    • Soldering irons become very hot when in use. Take all necessary precautions to avoid injury.
    If you just need to replace the LCD itself, the soldering isn't needed. The board is attached to the LCD with two small adhesive stripes. So you can remove the board, switch out the LCD and attach the board back again onto the new LCD. Worked like a charm.
    Sascha Brückl - Responder
  6. Nikon D5200 Screen Replacement: passo 6, imagem 1 %32 Nikon D5200 Screen Replacement: passo 6, imagem 2 %32 Nikon D5200 Screen Replacement: passo 6, imagem 3 %32
    • Using a spudger, remove the display from its casing.
    This helped me a great deal determining if it was my actual lcd or connection problem!
    rudy_saram - Responder
Conclusão
15 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Alexander Corn
Membro desde: 08/26/15
1.319 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 3-1, Eyestone Fall 2015 Membro de USF Tampa, Team 3-1, Eyestone Fall 2015
USFT-EYESTONE-F15S3G1
4 Membros
Autoria de 5 guias
11Comentários do guia
Do I need to de-solder if I'm just replacing the window glass?
isaac - Responder
To isaac: no. The exterior glass is separate from the LCD.
Joseph Morris - Responder
Do you recommend the replacent for LCD sold on Ebay?
g_atki - Responder
Where did you find the replacement screen? The one I ordered that says it's for the d5200 is not the same as the one in it or in your pictures.
Heather Miller - Responder
How do you disconnect the multi-plug that is shown connected in image 4 and disconnected in image five? Does it unclip or slide out?
Amanda Bruyninckx - Responder
The white latch on the right side for that ribbon won’t close. What should I do?
Gaojhia Vang - Responder
Does anyone know if the D5200 and D3300 share the same LCD screen? Ebay, Aliexpress, DHCamera show screens described as D3300/D5200 . I’d rather not pay $200 for a screen replacement I can do myself for <$25
Jeffrey Parker - Responder
Does anyone know if the LCD for the D5200 and D3300 are the same? I find screens listed as D5200/D3300
want to replace my D5100 LCD screen as it's already dying and I can't find D5100 LCD screens but found countless D5200 LCD replacement and just want to ask if the d5100 and d5200 share the same LCD?
they're the same 3" 920k screens and look the same too, just want confirmation as I don't want to buy a screen that won't fit mine 😅
Janarthanaan Thamizh Selvan - Responder
I bought the LCD screen on Ali for about 20$ this spring. It is compatible to D5200 and D3300. I just have to replace the LCD screen itself. No electronic part replacement and no soldering.
The white multiplug connector is firmly applied. You have to take care to open it, but need a bit pressure. The plug for the smaller cable is also a multiplug. You have to clip up the black part.
eagleforce - Responder
I bought a screen from ebay and it didnt come with the circuitboard.
I did the same as eagleforce.
I decided rather than mess about with soldering, I disconnected the LCD ribbon (larger brown one, lift white clip first then pulls out) and the LED panel (smaller brown one, I pulled this one out).
My new one came with the metal backing etc so took that all off (dont need it), I was left with just the LED and LCD (I did this on the new screen before taking the original one out so knew the process and that it was possible). I then did the same with the original one and swapped them.
Disconnecting the ribbons is always a delicate process, the pictures above show it well, Just be sure to use a wide prying tool not a small flat head screwdriver as the white bit will snap as too much pressure in one area.
Shaun Rainer - Responder
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 24
Últimos 30 dias: 102
Ao todo: 12,938
