Nikon D3100 LCD Screen Replacement
Introdução
Ir para o passo 1If your Nikon D3100 LCD screen is cracked, chipped, or flickering it may need to be replaced. Follow this guide to replace the LCD screen. But first take a look at this troubleshooting page to check if the problem is truly the LCD screen and not a setting issue.
O que você precisa
Remove two of the 4mm screws indicated by the circles on the bottom side of the camera.
Ferramenta utilizada neste passo:Tweezers$4.99
Starting from the top, gently lift the back panel of the camera off. Slowly separate the back panel from the main body of the camera.
Carefully remove the ribbon using a spudger to lift up the connector and then use tweezers to pull out the ribbon.
Separate the back panel from the main body of the camera.
8 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all5Comentários do guia
Very helpful guide, so happy to have a non-cracked screen again!
now, where can i buy this replacement screen here in the Philippines?
does anyone have the part number for the replacement screen?
Hello, regarde ici ça devrait correspondre:
