Ir para o conteúdo principal
Nikon Coolpix L830 LCD Monitor Replacement
Blake Johnson
Blake Johnson e 3 outros colaboradores
Última atualização em 3 de jul de 2020
20 minutos
Fácil
Introdução
Ir para o passo 1
If the LCD monitor on your Nikon Coolpix L830 is corrupted or completely blank, replacement is necessary. Following these steps will allow you to replace the broken screen with a new one to allow complete monitor functionality to return.
O que você precisa
Ferramentas
Exibir mais…
  1. Nikon Coolpix L830 LCD Monitor Replacement, LCD Monitor: passo 1, imagem 1 %32
    • Use a Phillips head P000 screwdriver to remove the four 3.0 mm Phillips screws on the back of the monitor.
  2. Nikon Coolpix L830 LCD Monitor Replacement: passo 2, imagem 1 %32
    • Use a Phillips head P000 screwdriver to remove the two 3.0 mm Phillips screws on the hinge cover.
  3. Nikon Coolpix L830 LCD Monitor Replacement: passo 3, imagem 1 %32 Nikon Coolpix L830 LCD Monitor Replacement: passo 3, imagem 2 %32
    • Remove the top hinge cover.
    • The top hinge cover contains screw holes.
    • Remove the bottom hinge cover.
    • The bottom hinge cover contains no screw holes.
  4. Nikon Coolpix L830 LCD Monitor Replacement: passo 4, imagem 1 %32
    • Remove the back cover of the LCD monitor with your hands or a plastic opening tool.
    • The cover will slide down the hinge, but it will not be completely removed.
  5. Nikon Coolpix L830 LCD Monitor Replacement: passo 5, imagem 1 %32 Nikon Coolpix L830 LCD Monitor Replacement: passo 5, imagem 2 %32
    • Use your thumb to gently pull the small flex ribbon wire connector from its socket.
    • Use your thumb to gently pull the wide flex ribbon wire connector from its socket.
  6. Nikon Coolpix L830 LCD Monitor Replacement: passo 6, imagem 1 %32
    • Use a plastic opening tool to remove the front cover of the LCD monitor, allowing the monitor to be completely be released.
  7. Nikon Coolpix L830 LCD Monitor Replacement: passo 7, imagem 1 %32
    • Gently remove the old, damaged LCD monitor.
Conclusão
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
Blake Johnson
Membro desde: 10/28/16
359 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 4-4, Williams Fall 2016 Membro de Baylor, Team 4-4, Williams Fall 2016
BU-WILLIAMS-F16S4G4
3 Membros
Autoria de 10 guias
2Comentários do guia
I cant remove two of the screws. Help
jo Hogan - Responder
Très bien pour démonter , mais pour remonter les nappes, notamment la moins large, je n'arrive pas à l'insérer !
Avez vous une technique à me proposer ?
Michel Cassel - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 2,886
