Ir para o conteúdo principal
Nikon Coolpix L830 Battery Cover Replacement
Blake Johnson
Blake Johnson e 3 outros colaboradores
Última atualização em July 2, 2020
10 minutos
Fácil
Introdução
Ir para o passo 1
If the battery cover on your Nikon Coolpix L830 is broken, replacement is necessary. Following these steps will allow you to replace the broken battery cover with a new one to allow your camera to stay powered and prevent the environment from affecting their performance.
O que você precisa
Ferramentas
Exibir mais…
  1. Nikon Coolpix L830 Battery Cover Replacement, Back Casing: passo 1, imagem 1 %32
    • Use a Phillips #000 screwdriver to unscrew the two 3.0mm Phillips screws located on the side of the camera with the HDMI port.
    • The HDMI port side will be on the left if you are looking at the back of the camera with the LCD monitor.
    • One screw is located under the gray flap.
  2. Nikon Coolpix L830 Battery Cover Replacement: passo 2, imagem 1 %32
    • Unscrew the five 3.0mm Phillips #000 screws that are located on the bottom side of the camera.
  3. Nikon Coolpix L830 Battery Cover Replacement: passo 3, imagem 1 %32
    • Unscrew the 4.0mm Phillips #000 screw located underneath the grey flap on the side of the camera with the "DC IN 5.0 V" marker.
    • This will be on the right if you are looking at the back LCD monitor side.
    • Unscrew the exposed 3.0mm Phillips #000 screw on the same side.
  4. Nikon Coolpix L830 Battery Cover Replacement: passo 4, imagem 1 %32
    • Press the flash button to open the flash component.
    • Remove the 3.0mm Phillips #000 screw located directly in-between the two arms.
  5. Nikon Coolpix L830 Battery Cover Replacement: passo 5, imagem 1 %32
    • Open the LCD monitor to reveal two 2.0mm Phillips screws.
    • Remove the 2.0mm Phillips #000 screws.
  6. Nikon Coolpix L830 Battery Cover Replacement: passo 6, imagem 1 %32 Nikon Coolpix L830 Battery Cover Replacement: passo 6, imagem 2 %32
    • Make sure to open the plastic grey flaps on either side of the camera before proceeding with this step.
    • Insert a plastic opening tool between the back and front surface components of the camera.
    • Wiggle the plastic opening tool backwards and forwards along the top edge until the back surface comes off.
    • Remove the back casing gently to not damage the LCD ribbon connector or inner camera components.
  7. Nikon Coolpix L830 Battery Cover Replacement: passo 7, imagem 1 %32 Nikon Coolpix L830 Battery Cover Replacement: passo 7, imagem 2 %32
    • Gently pull the LCD ribbon connector up to allow the back casing to be completely removed.
  8. Nikon Coolpix L830 Battery Cover Replacement, Battery Cover: passo 8, imagem 1 %32 Nikon Coolpix L830 Battery Cover Replacement, Battery Cover: passo 8, imagem 2 %32
    • Using the needle nose pliers, remove the straight pin holding in the battery cover.
  9. Nikon Coolpix L830 Battery Cover Replacement: passo 9, imagem 1 %32
    • Lift off the battery cover to completely remove it.
Conclusão
5 outras pessoas executaram este guia.
Blake Johnson
Membro desde: 10/28/16
347 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 4-4, Williams Fall 2016 Membro de Baylor, Team 4-4, Williams Fall 2016
BU-WILLIAMS-F16S4G4
3 Membros
Autoria de 10 guias
4 comentários
I did it!!! Sweat bullets, nearly damaged the LCD ribbon connector (a really difficult task pulling this up, be careful!!) but now camera is back in 1 piece and works. Thank you for your tutorial. I know I will NOT start a career changing these for others. Too nerve racking !!
Wim Schweer - Responder
I have a messed up usb port. I’m sure I could change it out . Where could I find a replacement usb/HDMI assembly?
David Allen - Responder
How can you remove the battery compartment? Mine has battery leakage and the center battery tube is full of electrolyte. I need to get that housing out and the center contact clean. Any ideas?
Help me J - Responder
I just disassembled an L310 last night and it was a major pain in the ***. I can't speak to the 830, but they look like similar design. To get at the battery compartment on the 310, I had to remove essentially everything, the front and back housing pieces, the screen, multiple circuit boards, the lens, the flash compartment, etc... It's like the camera was literally built around the battery compartment. The 830 looks like it's built the same way, with 100+ screws with several that will want to strip on you.
You could try using cotton swabs with vinegar on them. Distilled white vinegar will chemically eat the corrosion. Just take your time and do it slow. Don't get impatient and pour a large amount of vinegar into the battery compartment, it'll go everywhere inside the camera and ultimately cause liquid corrosion...been there done that. Best of luck with it!
Daniel -
Comentar
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 40
Últimos 30 dias: 100
Ao todo: 7,450
