Ir para o conteúdo principal
Nikon Coolpix B700 LCD Screen Replacement
Carlos Salgado
Carlos Salgado e 3 outros colaboradores
Última atualização em 1 de nov de 2024
10 minutos
Difícil
Introdução
Ir para o passo 1
The LCD screen can be easily replaced without removing any other parts from the device. If the LCD screen is cracked or the backlight is inoperable, refer to this replacement guide.
O que você precisa
Ferramentas
Exibir mais…
  1. Nikon Coolpix B700 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Nikon Coolpix B700 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 3.5mm screws at the top and bottom of the LCD Screen.
  2. Nikon Coolpix B700 LCD Screen Replacement: passo 2, imagem 1 %32 Nikon Coolpix B700 LCD Screen Replacement: passo 2, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 3.5mm screws on both sides of the side of the screen.
  3. Nikon Coolpix B700 LCD Screen Replacement: passo 3, imagem 1 %32
    • Use to metal spudger to pry open the LCD cover. Then slide it down the length of the screen until the cover comes apart.
  4. Nikon Coolpix B700 LCD Screen Replacement: passo 4, imagem 1 %32
    • Use the pry tool and slide it under the black tab and lift up gently. Do this again for the other two ZIF tabs.
  5. Nikon Coolpix B700 LCD Screen Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    Desoldering Pump
    $3.99
    • Use the solder gun and desolder the yellow and blue wires.
  6. Nikon Coolpix B700 LCD Screen Replacement: passo 6, imagem 1 %32
    • Use the jimmy and slide it in between the LCD screen and lift out the LCD Screen.
    Bonjour,
    Ce tutoriel est vraiment super,mais oú peut on trouver l'écran de rechange ? Ai commandé sur internet et pas reçu le même modèle
    Pascal Lecourt - Responder
Conclusão
Gear Up For Future Repairs
Shop all
2Comentários do guia
Hi, I like the first 6 steps, but what are the rest of the steps?
Kevin Kirkendall - Responder
My camera the screen go’s when outside and if it cold.
gsb1306 - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 28
Ao todo: 2,747
