Ir para o conteúdo principal
Nerf N-Strike Elite Strongarm Main Spring Replacement
Robert
Robert e 4 outros colaboradores
Última atualização em January 7, 2016
Nenhuma estimativa
Moderado
Fotos de ação
O que você precisa
Ferramentas
  1. Nerf N-Strike Elite Strongarm Main Spring Replacement, Main Spring: passo 1, imagem 1 %32
    • Remove the outside cover of the Nerf gun (cover and charging slide, 12 Phillips #0 screws).
  2. Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 2, imagem 1 %32
    • From the base, lift the action and the trigger.
  3. Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 3, imagem 1 %32
    • Lift the Nerf dart cylinder and the firing mechanism (spring chamber).
  4. Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 4, imagem 1 %32 Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 4, imagem 2 %32 Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 4, imagem 3 %32
    • Unscrew screws (2) from the cylinder rotator mechanism.
  5. Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 5, imagem 1 %32
    • Remove the air plunger and the spring from inside the chamber.
  6. Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 6, imagem 1 %32 Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 6, imagem 2 %32 Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 6, imagem 3 %32
    • Turn the spring counter-clockwise to free the spring. Be careful at the beginning and the end of the process.
  7. Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 7, imagem 1 %32 Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 7, imagem 2 %32 Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 7, imagem 3 %32
    • Replace the spring.
    • The spring will be greasy. Don’t be alarmed. Be careful at the beginning and the end of the process because it is like getting a key ring on at the notches, particularly at the top of the chamber.
    • Tip: If dry, use a little vegetable oil on the O-ring before putting it back.
  8. Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 8, imagem 1 %32
    • Return the plunger to the spring chamber.
  9. Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 9, imagem 1 %32 Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 9, imagem 2 %32
    • Screw the cover back onto the cylinder rotator.
  10. Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 10, imagem 1 %32
    • Place the spring chamber and the Nerf bullet cylinder back into the base.
  11. Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 11, imagem 1 %32 Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 11, imagem 2 %32
    • Screw the trigger and the action back in. Swing the gray gun charging slide out when putting the action back in.
  12. Nerf N-Strike Elite Strongarm Main Spring Replacement: passo 12, imagem 1 %32
    • Secure the cover and the charging slide with the 12 screws.
Conclusão
5 outras pessoas executaram este guia.
Robert
Membro desde: 03/18/15
192 Reputação
Autoria de 1 guia
4 comentários
Where can I buy a replacement spring?
mike580358 - Responder
you can get a replacement or an upgrade spring at the website www.nfstrike.com
NEW CHANNEL -
When I put it back together it did not work
autisteck - Responder
My kid got sand in this blaster and i was tasked with fixing. i degreased the parts and used a plastic grease to re lube, but it was too thick for the plunger so the darts limped out the barrel. so i opened it up and used some fogging oil in there after cleaning it out. works a treat. The biggest problem was the little spring on the barrel.. I lost it 4 times, and the fifth it was gone. So i used a spring from a clicky pen and it works great now!
tiderfish - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 50
Ao todo: 16,738
