Mavic 2 Main Board Replacement
20 - 30 minutos
Fácil
Introdução
Ir para o passo 1- Turn drone upside down to expose underside plate.
- Begin to remove all 8 screws from the plate . Remember the 2 middle screws are bigger than the other 6 so set those aside separately.
- Pull plate off, exposing the main board.
- Detach 3 ribbons on the top of the board. Near the head of the drone. Use spreader.
- Remove screw holding circuit board in. 1 near the top, 2 near the bottom.
- Pop of all 4 antennas at the bottom of the circuit board. Use spreader.
- Pull away antennas and remove board carefully.
- Replace new circuit board.
- Attach 3 ribbons.
- Attach 4 antennas.
- Screw circuit board back in.
- Place the plate back on and screw back in all 8 screws.
O que você precisa
Ferramentas
Quase terminado!
Conclusão
