Ir para o conteúdo principal
Magic Bullet NutriBullet Pro Rubber Gasket Replacement
Andrew Pana
Andrew Pana e 4 outros colaboradores
Última atualização em May 7, 2024
1 minuto
Fácil
Introdução
Ir para o passo 1
This guide will demonstrate how to replace a damaged rubber gasket on the blender blade lid of your cup. The rubber gasket is responsible for sealing the cup from leaking. Other possible problems can be found in our Troubleshooting Guide.
O que você precisa
Ferramentas
  1. Magic Bullet NutriBullet Pro Rubber Gasket Replacement, Rubber Gasket: passo 1, imagem 1 %32
    • Unscrew the blending blade lid from the cup.
  2. Magic Bullet NutriBullet Pro Rubber Gasket Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to peel back the rubber gasket that surrounds the inner ring of the lid.
    Now what?
    bthull@rogers.com
    Brian - Responder
    What is step three…
    bthull@rogers.com
    Brian - Responder
    Is the gasket supposed to be loose or glued in place?
    Brian - Responder
    His Step 3 is to "Reverse the process" which is NOT helpful at all. I think I would need about 4 hands to keep the gasket in the groove while turning the base to complete the circle. This was not usefull!
    Jon Findley - Responder
Conclusão
Andrew Pana
Membro desde: 10/03/16
191 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-4, Forte Fall 2016 Membro de Cal Poly, Team 18-4, Forte Fall 2016
CPSU-FORTE-F16S18G4
4 Membros
Autoria de 4 guias
3Comentários do guia
AWESOME! No more leaks. Such an easy fix. Thank you
campwallaby - Responder
thanks but how do you get the new gasket back on????????
jano3 - Responder
The Blade is very tight and doesn’t rotate with hands when i tried. How to fix it
Sunny - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 4,377
