Ir para o conteúdo principal
MSI MS-1782 Wi-Fi Card Replacement
A'kia
A'kia e 2 outros colaboradores
Última atualização em May 26, 2023
5 minutos
Fácil
This guide will show you how to replace the Wi-Fi card in a MSI MS-1782 laptop. If you are having trouble connecting to the Wi-Fi after exhausting all software fixes, use this guide to replace the Wi-Fi card. There are also steps you should do before the disassembly, like unplugging the battery.
O que você precisa
Ferramentas
Exibir mais…
  1. MSI MS-1782 Wi-Fi Card Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Wi-Fi Card Replacement: passo 2, imagem 1 %32 MSI MS-1782 Wi-Fi Card Replacement: passo 2, imagem 2 %32 MSI MS-1782 Wi-Fi Card Replacement: passo 2, imagem 3 %32
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 1 %32 MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 2 %32 MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 3 %32
    • Use the flat end of a spudger to detach the two antenna cables from the Wi-Fi card.
  4. MSI MS-1782 Wi-Fi Card Replacement: passo 4, imagem 1 %32 MSI MS-1782 Wi-Fi Card Replacement: passo 4, imagem 2 %32
    • Remove the 5 mm screw holding the Wi-Fi card in place with a JIS #1 screwdriver.
  5. MSI MS-1782 Wi-Fi Card Replacement: passo 5, imagem 1 %32 MSI MS-1782 Wi-Fi Card Replacement: passo 5, imagem 2 %32
    • Remove the Wi-Fi card at its angle.
Conclusão
To reassemble your device, follow these instructions in reverse order and make sure you put the antenna wires back in the correct order.
A'kia
Membro desde: 03/08/23
193 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 20
Duração total: 153
