Ir para o conteúdo principal
Logitech MBJ58 Mouse Support Spring Replacement
Conor Whatley
Conor Whatley e 14 outros colaboradores
Última atualização em 5 de dez de 2022
5 minutos
Moderado
Introdução
Ir para o passo 1
Use this guide to replace a faulty support spring in your Logitech MBJ58 Mouse.
This spring is responsible for keeping the scroll wheel in proper alignment with the components of the mouse. Over time, this spring can start to wear out and lose its ability to do this. Once that happens, it is a good idea to start considering replacing the spring to keep the mouse scroll wheel functioning correctly.
O que você precisa
Ferramentas
  1. Logitech MBJ58 Mouse Support Spring Replacement, Top cover: passo 1, imagem 1 %32
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    باز کردن پیچ زیر موس
    h sh - Responder
    There may be a sticker covering the screw hole.
    Eric Jensen - Responder
  2. Logitech MBJ58 Mouse Support Spring Replacement: passo 2, imagem 1 %32 Logitech MBJ58 Mouse Support Spring Replacement: passo 2, imagem 2 %32
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    جدا کردن قاب رو و زیر موس
    h sh - Responder
    The cover doesn’t lift straight up on my model - once you raise the back slightly as shown, gently pull it backward (parallel to the table top, away from the cord) to disengage two plastic clips that connect the bottom to the top.
  3. Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, imagem 1 %32 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, imagem 2 %32 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, imagem 3 %32
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    خارج کردن چرخ اسکرول موس
    h sh - Responder
    Good information!
    My mouse is like new again.
    Many thanks
    Arie Dekker - Responder
  4. Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: passo 4, imagem 1 %32 Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: passo 4, imagem 2 %32
    • Locate the spring on the scroll wheel, and carefully remove the spring.
    نحوه قرارگیری فنر سمت راست چرخ اسکرول
    h sh - Responder
  5. Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: passo 5, imagem 1 %32 Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: passo 5, imagem 2 %32
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    h sh - Responder
Conclusão
6 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Conor Whatley
Membro desde: 01/11/13
510 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 5-14, Forte Winter 2013 Membro de Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Membros
Autoria de 23 guias
1Comentário do guia
The thing with the spring - still in 2024 helpful!
Thanks a lot! :-)
Michaela Meyer - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 50
Ao todo: 4,374
