Ir para o conteúdo principal
Logitech K850 Disassembly
Marcus Jones
Marcus Jones e 2 outros colaboradores
Última atualização em May 7, 2024
15 - 30 minutos
Moderado
Guia colaborativo
O que você precisa
Ferramentas
Exibir mais…
  1. Logitech K850 Disassembly, Removing Batteries: passo 1, imagem 1 %32 Logitech K850 Disassembly, Removing Batteries: passo 1, imagem 2 %32 Logitech K850 Disassembly, Removing Batteries: passo 1, imagem 3 %32
    • Pry open the battery cover on the back of the device using either your hand or a spudger.
    • Use a spudger to remove the first battery.
    • Slide the 2nd battery out of the slot.
  2. Logitech K850 Disassembly, Unscrewing Screws: passo 2, imagem 1 %32 Logitech K850 Disassembly, Unscrewing Screws: passo 2, imagem 2 %32 Logitech K850 Disassembly, Unscrewing Screws: passo 2, imagem 3 %32
    • Unscrew the highlighted red screws using a Phillips 000 screwdriver.
    • Some screws are hidden under the rubber feet so you will have to pry off the rubber feet.
    • There are 2 screws under the keyboard's kickstand.
    PH000 was way to small/wobbly for my KBD (maybe the size changed over the years).
    PH0 was perfect match
    ZZZ ZZX - Responder
  3. Logitech K850 Disassembly, Separating The  Halves: passo 3, imagem 1 %32
    • Insert a spudger into the seam between the black side (front) and the white side (back).
    • Pry the two halves apart, making your way around the keyboard.
    • Be careful while prying, or else you may break the two plastic clips that hold the sides together.
    I think it would help to have a photo with arrows showing where the clips are and which way to pry to release them.
    David Limbert - Responder
    I was able to use slotted 3/32 tip (from Husky 74501 set) - the other side of PH0
    ZZZ ZZX - Responder
  4. Logitech K850 Disassembly, Removing The Palm Rest: passo 4, imagem 1 %32 Logitech K850 Disassembly, Removing The Palm Rest: passo 4, imagem 2 %32
    • Flip the black side (front) over so the keys face downwards.
    • Remove the red highlighted screws, then remove the palm rest.
  5. Logitech K850 Disassembly, Unscrewing The Circuit Boards: passo 5, imagem 1 %32 Logitech K850 Disassembly, Unscrewing The Circuit Boards: passo 5, imagem 2 %32 Logitech K850 Disassembly, Unscrewing The Circuit Boards: passo 5, imagem 3 %32
    • Unscrew the circuit boards using a Phillips 000 screwdriver.
    Great guide. Are replacement circuit boards available?
    Dan - Responder
  6. Logitech K850 Disassembly, Freeing The Battery Connectors: passo 6, imagem 1 %32 Logitech K850 Disassembly, Freeing The Battery Connectors: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to bring the metal rods under and over the plastic hooks.
    • Approach with caution, you can break the metal rod and/ or the plastic hooks if you are too aggressive.
    • Unplug the ribbon cable connecting the two boards and remove the power switch daughter board.
    • Unplug the ribbon cable connecting the membrane to the main circuit board.
    Nice guide, thanks.
    Any idea whether or not one can purchase a replacement power switch daughter board?
    Dan - Responder
    • Peel off the membrane.
    Would anyone have an idea why would 4 keys on the same printed circuit line [F1 1 2 T] fail to recover after cleaning/drying spilled wine? Membrane was supposed to prevent liquid from going further but it didn't. No visible damages to the circuit. The fn keys (on the same line as these 4) appear to be functional, except that pressing them alone (without an F-key) lights up current connection indicator [1 - 2 - 3]. Don' know if that's normal behavior on a virgin KBD.
    Z Z - Responder
    The circuit under the membrane is multi-layered, maybe the wine got in between the layers.
    Marcus Jones -
    How do you suggest what to use to thoroughly clean the membrane parts of the keyboard?
    Can they be washed in warm soapy (like dawn) water and dried with warm hair dryer?
    Michael Rosen - Responder
    Warm soapy water works well to clean the membranes. Do pay attention to the temperature of the membrane, as it can get very hot to the touch easily.
    Marcus Jones -
Conclusão
The Logitech K850 keyboard is quite complex, though it is somewhat easy to fix. However, with a ton of fragile components that need to be pried on, repairs can be difficult.
3 outras pessoas executaram este guia.
Marcus Jones
Membro desde: 11/22/18
1.247 Reputação
Autoria de 6 guias
2Comentários do guia
How do I fix the incredibly tiny plastic piece where the foot/stand fits into? Are the side wholes enough to get two new feet without having to worry about that plastic part or does it need ot hook into that?
Danny Romero - Responder
It is difficult for key plucker to remove keys from.mk850 . Is there a easy way to remove keys from it?
Suman Kalyan - Responder
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 32
Últimos 30 dias: 143
Ao todo: 10,148
