Ir para o conteúdo principal
Logitech G920 Driving Force XYAB Buttons Replacement
Tristyn Dolan
Tristyn Dolan e 4 outros colaboradores
Última atualização em December 18, 2023
15 - 25 minutos
Moderado
Introdução
Ir para o passo 1
This guide will be used to aid you in replacing the Logitech G920 Driving Force XYAB buttons. The steering wheel buttons control the inputs when pressing down on them. If your device is having problems related to the buttons not responding, take a look at the troubleshooting guide before continuing with this guide. The problems related to buttons could also be a result of a faulty motherboard. However, if you know it's a problem with the buttons themselves, continue with this replacement guide. Unplug all parts of the device from any outlets before you start.
O que você precisa
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Logitech G920 Driving Force XYAB Buttons Replacement, Steering Wheel Motherboard: passo 1, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
    • Only three of the five screws are visible from each side of the wheel due to the center unit.
  2. Logitech G920 Driving Force XYAB Buttons Replacement: passo 2, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
  3. Logitech G920 Driving Force XYAB Buttons Replacement: passo 3, imagem 1 %32 Logitech G920 Driving Force XYAB Buttons Replacement: passo 3, imagem 2 %32
    • Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
    • Remove the face plate from the steering wheel.
  4. Logitech G920 Driving Force XYAB Buttons Replacement: passo 4, imagem 1 %32 Logitech G920 Driving Force XYAB Buttons Replacement: passo 4, imagem 2 %32
    • Remove the wheel from the main steering wheel console.
    • Ensure this is done carefully as to not damage the connection wire.
  5. Logitech G920 Driving Force XYAB Buttons Replacement: passo 5, imagem 1 %32 Logitech G920 Driving Force XYAB Buttons Replacement: passo 5, imagem 2 %32
    • Remove the eight 7.5 mm screws holding the steering wheel motherboard in place using a Phillips #0 screwdriver.
    • Remove the steering wheel motherboard.
  6. Logitech G920 Driving Force XYAB Buttons Replacement, XYAB Buttons: passo 6, imagem 1 %32
    • Remove the XYAB buttons from the back of the steering wheel.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 36
Ao todo: 524
