Ir para o conteúdo principal
Lite-On iHAS324 Eject Button and Power LED Light Replacement
Kayla Culpepper
Kayla Culpepper e 3 outros colaboradores
Última atualização em May 29, 2023
15 - 30 minutos
Difícil
Melhor Introdução
  1. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Chassis: passo 1, imagem 1 %32 Lite-On iHAS324 Eject Button and Power LED Light Replacement, Chassis: passo 1, imagem 2 %32
    • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
    • There may be resistance, do not be afraid to use force.
    • The tray should then pop open.
    • Pull out the tray so that it is fully extended.
  2. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 2, imagem 1 %32 Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 2, imagem 2 %32 Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
  3. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 3, imagem 1 %32
    • Pull the faceplate off the chassis.
    • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
  4. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 4, imagem 1 %32
    • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
  5. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 5, imagem 1 %32
    • Remove the bottom plate by lifting it off the device.
  6. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 6, imagem 1 %32
    • Turn the device over.
    • Remove the top plate by pulling the sides and lifting the plate off.
  7. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray: passo 7, imagem 1 %32 Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray: passo 7, imagem 2 %32
    • Push the left tab in and slide the tray out on the left side.
    • Pull the gray plastic casing on the right side away from the tray.
    • Slide the right side of the tray out.
  8. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray Belt: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Take tweezers and remove the black tray belt from the gears carefully.
  9. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Eject Button and Power LED Light: passo 9, imagem 1 %32
    • Flip the device over.
  10. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 10, imagem 1 %32
    • Use a plastic opening tool to pull all three tabs, lifting up the circuit board as you go.
  11. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 11, imagem 1 %32
    • Carefully lift the circuit board out of the plastic casing.
  12. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 12, imagem 1 %32
    • Using a solder wick, unsolder either the eject button or Power LED Light. Soldering Guide
    • Then, using a solder iron, replace them.
Conclusão
Kayla Culpepper
Membro desde: 03/22/15
702 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 5-9, Williams Spring 2015 Membro de Baylor, Team 5-9, Williams Spring 2015
BU-WILLIAMS-S15S5G9
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 18
Duração total: 844
