Ir para o conteúdo principal
Lenovo Thinkpad Yoga 370  M2 SSD Replacement
Ramiro
Ramiro e 2 outros colaboradores
Última atualização em 15 de nov de 2022
7 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
Here it is explained step by step how to replace a M2 SSD of the Lenovo Thinkpad Yoga 370. The specific model code can be found in the sticker with the serial number. In my case it is 20JJ. The materials I have used are:
  • New M2 SSD compatible with your model
  • Screw like Phillips #1 Screwdriver or the tool provided on iFixit Tool.
I recommend to download also from Lenovo the official guides of your laptop as they have diagrams with the description of the motherboards and its components. In my case:
https://download.lenovo.com/pccbbs/mobil...
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Identify the specific model and locate the screws to loose: passo 1, imagem 1 %32 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Identify the specific model and locate the screws to loose: passo 1, imagem 2 %32
    • Before remove the back-case of the laptop we have to remove the Pen Pro and the SD card if it is in your model (two boxes in orange on one of the photos).
    • Circles show the screws to loose. The yellow square indicates where the information about Model is found (20JJ in this case).
  2. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Loose the screws and take away the back case: passo 2, imagem 1 %32 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Loose the screws and take away the back case: passo 2, imagem 2 %32 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Loose the screws and take away the back case: passo 2, imagem 3 %32
    • Note that after loose the screws we have to remove the case from the bottom part.
    • The all the screws remain attached to the back-cover as shown in the photos.
    • Note that the top part of the laptop back cover has several hooks done with plastic (see the photos with blue squares)
  3. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Identify the M2.SSD and the screw that attach it to the main board: passo 3, imagem 1 %32 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Identify the M2.SSD and the screw that attach it to the main board: passo 3, imagem 2 %32
    • Laptop after remove the back-cover. The area in red has the M2.SSD.
    • The blue arrow shows where is the adhesive part of the M2.SSD that we have to carefully lift off but keeping attached the other part of the cover.
    • The green arrow shows the screw that we would have to remove to take away the M2.SSD.
  4. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Remove the screw and insert the M2.SSD.: passo 4, imagem 1 %32 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Remove the screw and insert the M2.SSD.: passo 4, imagem 2 %32 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Remove the screw and insert the M2.SSD.: passo 4, imagem 3 %32
    • First step is remove the screw (this one has to be full removed).
    • Then we can introduce the new M2.SSD, with a little bit of pressure.
    • Finally we can fix it with the previously removed screw. Everything should fit well without forcing any component.
  5. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Attach again the back case.: passo 5, imagem 1 %32
    • To close the back case of the laptop we have to remember the position of the small hooks. Then apply some pressure and screw first the screws on top
    • After screw again all the 9 screws, we can attach again the Pen Pro and the SD card.
    • Its done.
Conclusão
Documentos anexados
Gear Up For Future Repairs
Shop all
Ramiro
Membro desde: 03/08/19
178 Reputação
Autoria de 1 guia
1Comentário do guia
excellent and easy to follow instruction. I used your set and sent it to a senior that needed to fix their laptops. No prior experience. It worked like a charm.
Austin - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 54
Ao todo: 6,879
