Ir para o conteúdo principal
Lenovo ThinkPad T480 SSD Replacement
Dane Elliott-Dyson
Dane Elliott-Dyson e 3 outros colaboradores
Última atualização em September 23, 2024
10 - 15 minutos
Moderado
Guia colaborativo
Introdução
Ir para o passo 1
This guide will show you how to replace the SSD on your Lenovo Thinkpad T480 laptop. Backup your data before replacing if possible.
  1. Lenovo ThinkPad T480 SSD Replacement, SSD: passo 1, imagem 1 %32
  2. Lenovo ThinkPad T480 SSD Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T480 SSD Replacement: passo 2, imagem 2 %32
    • Push Clip 1 to the side. While holding Clip 2 to the side, push the battery out of the laptop.
  3. Lenovo ThinkPad T480 SSD Replacement: passo 3, imagem 1 %32
    • Remove all Phillip-head screws shown.
    • The screws will not come out of the casing, so unscrew them all the way until they don’t go any higher.
  4. Lenovo ThinkPad T480 SSD Replacement: passo 4, imagem 1 %32
    • Pry up on the casing using a spudger or a flat-head screwdriver and remove the back.
  5. Lenovo ThinkPad T480 SSD Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T480 SSD Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad T480 SSD Replacement: passo 5, imagem 3 %32
    • Pry up on the little metal bar on the connector and pull the connector out of its socket.
  6. Lenovo ThinkPad T480 SSD Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T480 SSD Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T480 SSD Replacement: passo 6, imagem 3 %32
    • Pry up on the left side of the SSD casing. Pull the casing to the left, and remove.
  7. Lenovo ThinkPad T480 SSD Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T480 SSD Replacement: passo 7, imagem 2 %32
    • Remove the following 4mm Phillip-head screws and remove the plate.
  8. Lenovo ThinkPad T480 SSD Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad T480 SSD Replacement: passo 8, imagem 2 %32 Lenovo ThinkPad T480 SSD Replacement: passo 8, imagem 3 %32
    • Remove the 4mm Phillip-head screw and pull the SSD out of its socket.
Conclusão
4 outras pessoas executaram este guia.
1Comentário do guia
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 96
Últimos 30 dias: 417
Ao todo: 6,514
