Ir para o conteúdo principal
Lenovo ThinkPad T480 Keyboard Replacement
Sarah Westberg
Sarah Westberg e um outro colaborador
Última atualização em December 20, 2023
10 - 20 minutos
Fácil
Introdução
Ir para o passo 1
If the keyboard becomes dirty, it loses keys, or it becomes non-functional, you might need to replace the keyboard of your Lenovo ThinkPad T480.
The keyboard is an integral component of your Lenovo ThinkPad T480. It is one of the main input devices of your laptop, allowing the user to enter data in the form of characters like numbers and letters into the computer.
This repair is an easy process. Just be sure to disable the internal battery, remove the external battery and unplug the device prior to beginning your fix. Also be careful when you remove the keyboard because it is connected to two cables on the underside that need to be detached.
O que você precisa
Peças
Ferramentas
  • Spudger
    Spudger
Exibir mais…
  1. Lenovo ThinkPad T480 Keyboard Replacement, External Battery: passo 1, imagem 1 %32 Lenovo ThinkPad T480 Keyboard Replacement, External Battery: passo 1, imagem 2 %32
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Keyboard Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 2, imagem 3 %32
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
  4. Lenovo ThinkPad T480 Keyboard Replacement: passo 4, imagem 1 %32
    • Open the laptop so the keyboard is facing you.
  5. Lenovo ThinkPad T480 Keyboard Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 5, imagem 3 %32
    • Push the keyboard towards the screen and away from the trackpad and then slide it out towards you gently.
    • The keyboard is connected to the board by two ribbon connectors.
    • Be careful not to rip the connectors when you flip the keyboard over.
  6. Lenovo ThinkPad T480 Keyboard Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 6, imagem 3 %32
    • Flip the keyboard over towards you to expose the backside of the keyboard and the two ribbon connectors.
    • Using the black nylon spudger, flip the first ribbon connector lock open. Slide the first connector out.
  7. Lenovo ThinkPad T480 Keyboard Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 7, imagem 2 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 7, imagem 3 %32
    • Using the black nylon spudger, unlock the second ribbon connector and slide it out from the port.
    Hello Sarah,
    Thanks for this great guide.
    I mistakenly broke this ribbon connector on my T480 and wish you will help with any info where to source a good one and how to fit it back. It has prevent my keyboard from working.
    Adeyinka Olugbade - Responder
  8. Lenovo ThinkPad T480 Keyboard Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 8, imagem 2 %32
    • Remove the keyboard from the laptop.
Conclusão
10 outras pessoas executaram este guia.
Sarah Westberg
Membro desde: 03/11/19
29.713 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
119 Membros
Autoria de 19.658 guias
3Comentários do guia
Thanks for this. I need help with my Lenovo Thinkpad T480 keyboard to motherboard connector pin. That is the third image in step 6.
Where can I get a replacement?
EagleCreeks Assortment - Responder
Hi @lioneeddev99026, You are most welcome. I'm glad the guide was helpful!
Sarah Westberg -
Comentar
Visualizações:
Últimas 24 horas: 19
Últimos 7 dias: 147
Últimos 30 dias: 654
Ao todo: 18,303
