Ir para o conteúdo principal
Lenovo ThinkPad T480 Hard Drive Prerequisite
Sarah Westberg
Sarah Westberg
Última atualização em August 17, 2023
20 - 30 minutos
Moderado
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
Introdução
Ir para o passo 1
The hard drive of your Lenovo ThinkPad T480 might become corrupted or you might want to upgrade it at some point. If you need to replace your hard drive, follow the instructions in this guide.
The hard drive is a nonvolatile data storage and retrieval device which uses magnetic storage on one or more rotating platters. In the hierarchy of computer storage, it is considered secondary storage.
If your hard drive fails, your computer will start to run extremely slow, it may overheat, fail to boot and you may get boot errors, “blue screen of death” errors, and apps will freeze or crash.
According to the Lenovo Forum, this model has the capacity to upgrade to 1 TB Solid State Drive, PCIe-NVMe OPAL2.0 M.2.
Be sure to disable the internal battery, turn off the computer, and unplug the laptop from the power adapter prior to starting the repair.
O que você precisa
Ferramentas
  • Phillips #1 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Exibir mais…
  1. Lenovo ThinkPad T480 Hard Drive Prerequisite, Hard Drive: passo 1, imagem 1 %32 Lenovo ThinkPad T480 Hard Drive Prerequisite, Hard Drive: passo 1, imagem 2 %32 Lenovo ThinkPad T480 Hard Drive Prerequisite, Hard Drive: passo 1, imagem 3 %32
    • Using the black nylon spudger, lift the connector lock up.
    • Disconnect the storage cable from the system board.
  2. Lenovo ThinkPad T480 Hard Drive Prerequisite: passo 2, imagem 1 %32 Lenovo ThinkPad T480 Hard Drive Prerequisite: passo 2, imagem 2 %32 Lenovo ThinkPad T480 Hard Drive Prerequisite: passo 2, imagem 3 %32
    • Lift the hard drive up with a tab if it has one or with your spudger.
    • Lift the drive assembly from the system.
Conclusão
Sarah Westberg
Membro desde: 03/11/19
29.668 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.623 guias
0 Guide Comments
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 63
