Ir para o conteúdo principal
Lenovo ThinkPad E570 Hard Drive Replacement
Peter Swanson
Peter Swanson e 6 outros colaboradores
Última atualização em July 19, 2023
15 minutos
Moderada
Guia do aluno destaque
This guide will show you how to replace the hard drive in your Lenovo ThinkPad E570 laptop. Is your device screen suddenly taking you to a blue screen with the message "Your PC ran into a problem and needs to restart?" Do other frequent error messages happen during normal operations? Do you have irregular system crashes and disk errors? This could be an indication of a faulty hard drive that needs to be replaced. Replacing the hard drive will ensure your device doesn't have frequent error messages and disappearing files and folders.
Power down your laptop and disconnect from any external power sources before beginning this guide. Also, be sure to back up the data from your device.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Lenovo ThinkPad E570 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Turn the laptop over so that the bottom is facing upwards.
  2. Lenovo ThinkPad E570 Hard Drive Replacement: passo 2, imagem 1 %32
    • Unscrew two captive 5 mm screws from the back panel of the laptop using a Phillips #00 screwdriver.
    • Carefully remove the back panel.
  3. Lenovo ThinkPad E570 Hard Drive Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad E570 Hard Drive Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad E570 Hard Drive Replacement: passo 3, imagem 3 %32
    • Carefully slide the hard drive to the left.
    • Remove the hard drive by lifting it up and out of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 32
Duração total: 1,120
