Ir para o conteúdo principal
LG G5 Camera Sensor Replacement
Parker Reynolds
Parker Reynolds e 4 outros colaboradores
Última atualização em April 23, 2018
8 minutos
Moderado
Introdução
Ir para o passo 1
In this guide, you will be removing the rear camera sensor. Use this guide if you find the rear camera has trouble focusing.
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. LG G5 Camera Sensor Replacement, Front Panel Assembly: passo 1, imagem 1 %32 LG G5 Camera Sensor Replacement, Front Panel Assembly: passo 1, imagem 2 %32
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Camera Sensor Replacement: passo 2, imagem 1 %32 LG G5 Camera Sensor Replacement: passo 2, imagem 2 %32 LG G5 Camera Sensor Replacement: passo 2, imagem 3 %32
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
  3. LG G5 Camera Sensor Replacement: passo 3, imagem 1 %32 LG G5 Camera Sensor Replacement: passo 3, imagem 2 %32
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Camera Sensor Replacement: passo 4, imagem 1 %32
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
    Holy this step is hard
    Nickstar - Responder
    It is, i can’t seem to do it too easily either. Maybe i need to heat it up? I don’t want to damage it as it will still be used as a camera.
    ayeeeee -
  5. LG G5 Camera Sensor Replacement: passo 5, imagem 1 %32 LG G5 Camera Sensor Replacement: passo 5, imagem 2 %32
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
    My LCD started to let loose using this way to saparate the top and bottom of the phone.
    I used a guitar pick and slided it from the bottom to the top like the dude in this video: https://www.youtube.com/watch?v=XV10zyw8...
    Didn’t had to use a lot of force this way, and my screen almost didn’t bend !
    Ray Bas - Responder
    Yep! I did it also with this method. Wayy better and easier ;)
    ronlad.garud -
    My screen cracked taking it out following ifixit method . Right when I got to the part where it starts to curve at the top. Just shattered.
    Randy - Responder
    I found it easier to run the tool or a pick along the sides, and then sort of hinge the thing open at the top rather than running completely around the screen. It gets a little dicey where the glass starts to curve.
    Arthur Heller - Responder
  6. LG G5 Camera Sensor Replacement: passo 6, imagem 1 %32 LG G5 Camera Sensor Replacement: passo 6, imagem 2 %32
    • Peel the screen away from the body. The two parts should be completely separated.
  7. LG G5 Camera Sensor Replacement, Screen: passo 7, imagem 1 %32 LG G5 Camera Sensor Replacement, Screen: passo 7, imagem 2 %32
    • Once the screen has been separated from the back of the phone, now you can remove the motherboard.
    • Using the #00 Philips head, remove the six 2.7mm Phillips screws.
    Pry up on the connector to remove the camera before trying to lift motherboard
    asears - Responder
    That is so important he needs to edit this quickly
    princeton2u - Responder
    need to remove the 1 back & the fromt camera connectors..
    Thorondor - Responder
  8. LG G5 Camera Sensor Replacement: passo 8, imagem 1 %32 LG G5 Camera Sensor Replacement: passo 8, imagem 2 %32
    • Insert the plastic opening tool between the screen-ribbon-connector and the motherboard, then pull up. It should pop out easily.
  9. LG G5 Camera Sensor Replacement: passo 9, imagem 1 %32
    • Separate the motherboard of the phone from the screen of the phone
    Don't forget to take out the speaker and the rubber parts that need to be transferred to the other frame.
    celldoctorsinc - Responder
    where and the !&&* are pictures or even any explanation whatsoever of replacing a cracked screen one wrong move via this poor por set instruction fricking breaks it all this guide should be removed now!
    fixitcrap - Responder
    I had to move over from old to new assembly:
    rubberpart next to speaker contacts
    flat plasticpart under speaker
    speaker
    rubberpart between speaker and front camera, sits then on two tiny sensors on motherboard
    all 3 cameras
    dl7utx - Responder
    We had to move to the new assembly:
    tiny rubber part to the left of the speaker contacts (pinned by the plastic speaker housing)
    speaker (aka earpiece - step 10)
    plastic speaker housing (aka earpiece casing - step 11)
    tiny front facing camera
    left rear camera (the middle rear camera stayed on the logic board).
    other than that, the guide, combined with careful observation, was help us successfully replace the broken screen.
    gmg - Responder
  10. LG G5 Camera Sensor Replacement: passo 10, imagem 1 %32 LG G5 Camera Sensor Replacement: passo 10, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Make sure to transfer the earpiece from the old screen to the new screen or else you wouldn't be able to hear anyone when you make phone calls!
    • The component is fragile so don't try to force it to come out with a pair of tweezers. A pick should be able to wedge it out.
    • Be careful with the adhesive that's connected to it. It's easy to pull out.
    I have a G5 SE. The earpiece is slightly different. I pried close to the screw and the whole plastic casing came out as one. Skip step 11. The regular G5 looks like this guide.
    Stephen Greydanus - Responder
  11. LG G5 Camera Sensor Replacement: passo 11, imagem 1 %32
    • Also remove the earpiece casing from the old screen by popping it out with a pair of tweezers.
    • On the new screen, place the casing down first and making sure that it's locked in place. Then place the earpiece on top of it. Gently push it down with your finger until it's secure.
  12. LG G5 Camera Sensor Replacement, Camera Sensor: passo 12, imagem 1 %32 LG G5 Camera Sensor Replacement, Camera Sensor: passo 12, imagem 2 %32 LG G5 Camera Sensor Replacement, Camera Sensor: passo 12, imagem 3 %32
    • Using the plastic opening tool, remove the ribbon attaching the sensor to the motherboard.
Conclusão
6 outras pessoas executaram este guia.
Parker Reynolds
Membro desde: 10/03/16
935 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 18-2, Forte Fall 2016 Membro de Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Membros
Autoria de 15 guias
1Comentário do guia
Is that the camera sensor that has been removed or the wide angle camera?
Thomas Charnley - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 4,486
