Kocaso M750B Camera Replacement
Introdução
Vá para o passo 1This guide will help you gain access to the camera of the Kocaso M750B. Before considering repair make sure to visit the Kocaso M750B Troubleshooting page to make sure a replacement is necessary. Also make sure to work carefully because there are many parts that when damaged, are dangerous and costly.
O que você precisa
Pry the battery up using the flat end of a spudger.
Remove the adhesive under the battery and carefully lift it up.
