Kenmore 110 Series Washing Machine Electronic Control Replacement
Introdução
Ir para o passo 1Use this guide to replace a faulty electronic control on your Kenmore 110 Washing Machine.
O que você precisa
Ferramentas
Exibir mais…
Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
Lifting from the rear, remove the top panel.
10 outras pessoas executaram este guia.
3Comentários do guia
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
I am having the same problem. Did you ever find a fix?
