Ir para o conteúdo principal
Jeans 2-Hole Button Replacement
O que você precisa
  1. Jeans 2-Hole Button Replacement, 2-Hole Button: passo 1, imagem 1 %32
    • Find a thread color that matches the fabric you are sewing the button on to.
  2. Jeans 2-Hole Button Replacement: passo 2, imagem 1 %32
    • Loop the thread through the eye of the needle.
    • Tie a small knot around the eye of the needle with the thread.
    • Make sure the knot is tight!
  3. Jeans 2-Hole Button Replacement: passo 3, imagem 1 %32
    • Thread the needle through the fabric from the inside out.
    • Tie a knot at the end of the thread after pulling most of it through the fabric.
  4. Jeans 2-Hole Button Replacement: passo 4, imagem 1 %32 Jeans 2-Hole Button Replacement: passo 4, imagem 2 %32 Jeans 2-Hole Button Replacement: passo 4, imagem 3 %32
    • Sew the thread in a small 'x' where you would like to place the button.
    • If you don't want to sew, then mark the spot with a white fabric marker.
  5. Jeans 2-Hole Button Replacement: passo 5, imagem 1 %32 Jeans 2-Hole Button Replacement: passo 5, imagem 2 %32 Jeans 2-Hole Button Replacement: passo 5, imagem 3 %32
    • Place the button over the small stitched 'x' or fabric marker spot.
    • Thread the needle through the left hole of the button from the inside out.
    • Pull the needle and thread all the way through the fabric.
    • If you can't find the hole of the button, thread the needle through the fabric first and then through the button hole.
  6. Jeans 2-Hole Button Replacement: passo 6, imagem 1 %32 Jeans 2-Hole Button Replacement: passo 6, imagem 2 %32 Jeans 2-Hole Button Replacement: passo 6, imagem 3 %32
    • Cross the needle over to the right hole of the button.
    • Thread the needle all the way through the fabric.
    • This step creates the first stitch.
  7. Jeans 2-Hole Button Replacement: passo 7, imagem 1 %32
    • Repeat Steps 6-7 four to five times, until you have a secure button.
  8. Jeans 2-Hole Button Replacement: passo 8, imagem 1 %32
    • Create a thread shank on the inside of the fabric by looping the thread around a stitch.
    • Pull the thread all the way through the hole until it is tight.
    • Repeat this 2-3 times.
    • Tie a knot after the final stitch to secure the stitches.
  9. Jeans 2-Hole Button Replacement: passo 9, imagem 1 %32 Jeans 2-Hole Button Replacement: passo 9, imagem 2 %32
    • Use fabric scissors to cut off excess thread.
Conclusão
After cutting the remaining thread, your button stays on your jeans.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 42
Duração total: 727
