Ir para o conteúdo principal
Sew a Button
O que você precisa
    1. Sew a Button, Sew a Button: passo 1, imagem 1 %32
      • Locate the area where the button has gone missing.
      Pergunte ao FixBot
      Comentar
    2. Sew a Button: passo 2, imagem 1 %32 Sew a Button: passo 2, imagem 2 %32
      • Overlap the buttonhole with where the button should be. Going through the buttonhole, mark the fabric below with tailor's chalk.
      Pergunte ao FixBot
      Comentar
    3. Sew a Button: passo 3, imagem 1 %32 Sew a Button: passo 3, imagem 2 %32
      • Get a length of thread—about an arms-length should be more than enough.
      • Thread a needle.
      Pergunte ao FixBot
      Comentar
    4. Sew a Button: passo 4, imagem 1 %32 Sew a Button: passo 4, imagem 2 %32 Sew a Button: passo 4, imagem 3 %32
      • Let the needle slide down the thread until it hangs at the center. You should have two equal lengths of thread on either side of the needle.
      • Tie the loose ends of the thread together.
      Pergunte ao FixBot
      Comentar
    5. Sew a Button: passo 5, imagem 1 %32 Sew a Button: passo 5, imagem 2 %32
      • Tie a second regular knot over the first one to make it bigger. You don't want the thread slipping right through the grain of the fabric.
      Pergunte ao FixBot
      Comentar
    6. Sew a Button: passo 6, imagem 1 %32 Sew a Button: passo 6, imagem 2 %32 Sew a Button: passo 6, imagem 3 %32
      • Poke the needle up through the chalk mark from the underside of the fabric.
      • Pull the thread taut, until the knot catches the backside of the fabric.
      Pergunte ao FixBot
      Comentar
    7. Sew a Button: passo 7, imagem 1 %32 Sew a Button: passo 7, imagem 2 %32
      • Thread the needle through one hole of the button. You can pick any hole to start with.
      • Let the button drop all the way down onto the fabric.
      Pergunte ao FixBot
      Comentar
    8. Sew a Button: passo 8, imagem 1 %32 Sew a Button: passo 8, imagem 2 %32 Sew a Button: passo 8, imagem 3 %32
      • Push the needle through the buttonhole directly opposite the one you have already threaded.
      • Be sure to go through only the button, not the fabric.
      Pergunte ao FixBot
      Comentar
    9. Sew a Button: passo 9, imagem 1 %32 Sew a Button: passo 9, imagem 2 %32 Sew a Button: passo 9, imagem 3 %32
      • Push the needle back through the fabric directly next to where you initially pushed the needle up.
      • Pull the thread taut, until the button lays flat on the fabric.
      Pergunte ao FixBot
      Comentar
    10. Sew a Button: passo 10, imagem 1 %32 Sew a Button: passo 10, imagem 2 %32 Sew a Button: passo 10, imagem 3 %32
      • Push the needle back up through the backside of the fabric, directly next to the original knot
      • Work the needle up through one of the two remaining holes without thread.
      • Pull the thread taut.
      Pergunte ao FixBot
      Comentar
    11. Sew a Button: passo 11, imagem 1 %32 Sew a Button: passo 11, imagem 2 %32 Sew a Button: passo 11, imagem 3 %32
      • Go back through the last remaining empty hole on the button.
      • Go back down through the fabric, as close as possible to the other two threads.
      Pergunte ao FixBot
      Comentar
    12. Sew a Button: passo 12, imagem 1 %32 Sew a Button: passo 12, imagem 2 %32 Sew a Button: passo 12, imagem 3 %32
      • Drive the needle back up through the underside of the fabric and into the first hole that you threaded.
      Pergunte ao FixBot
      Comentar
    13. Sew a Button: passo 13, imagem 1 %32 Sew a Button: passo 13, imagem 2 %32
      • Go back down through the second hole, directly across from the hole you just came up through.
      • Pull taut.
      Pergunte ao FixBot
      Comentar
    14. Sew a Button: passo 14, imagem 1 %32 Sew a Button: passo 14, imagem 2 %32 Sew a Button: passo 14, imagem 3 %32
      • Push the needle up through the third hole again.
      • Pull it taut.
      • Push the needle down through the fourth hole and pull it taut.
      • Repeat steps 12-14 of this guide one more time, then proceed.
      Pergunte ao FixBot
      Comentar
    15. Sew a Button: passo 15, imagem 1 %32 Sew a Button: passo 15, imagem 2 %32 Sew a Button: passo 15, imagem 3 %32
      • You have sewn in the button. Now you need a knot to keep the button in place.
      • Push the needle through the loops of thread on the underside of the fabric. Be careful not to catch the fabric.
      Pergunte ao FixBot
      Comentar
    16. Sew a Button: passo 16, imagem 1 %32 Sew a Button: passo 16, imagem 2 %32
      • Leave some slack in the thread and draw the needle through the loop created by the slack.
      • Pull the thread taut, forming a knot.
      • Repeat steps 15 and 16 one more time to add a second knot.
      Pergunte ao FixBot
      Comentar
    17. Sew a Button: passo 17, imagem 1 %32 Sew a Button: passo 17, imagem 2 %32
      • Clip the excess thread off.
      • Check your button for stability.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
64 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
90.988 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 34.796 guias
5Comentários do guia
What helps after the last step 14 is to wrap the thread around and around a few times underneath the button itself (binding all the threads together) and making one last pass through the cloth before the final knot. This makes the repair much more durable.
mccreerydennis - Responder Compartilhar
The wrapping below the button is not only more durable, but is actually frequently used when replacing buttons on blazers, sport coats, and the like as a protection from friction as the garment moves and shifts while being worn.
Matt - Responder Compartilhar
Wrapping the threads underneath the button to create a shank is useful for coat buttons where the fabric is thick and you don’t want the fabric to pucker. As noted, it adds durability to the button attachment. On a shirt collar, as seen here, it would create too much bulk where you need the button to lie quite flat, so this method is quite sufficient.
Jonathan Wells - Responder Compartilhar
Thanks Jonathan. Great insight.
Louie Leung - Responder Compartilhar
Parfait, mon pantalon est comme neuf :)
Brendan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 103
Últimos 30 dias: 408
Ao todo: 24,744
