Ir para o conteúdo principal
Instant Pot 60 EPC Button Panel Replacement
Bela Hernandez
Bela Hernandez e 3 outros colaboradores
Última atualização em January 3, 2025
45 minutos
Moderado
Introdução
Ir para o passo 1
The following guide is from replacing the front panel of an Instant Pot 60 EPC. Consider following this guide if you have issues with unresponsive buttons, random error codes, or a flickering screen display.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Instant Pot 60 EPC Button Panel Replacement, Button Panel: passo 1, imagem 1 %32 Instant Pot 60 EPC Button Panel Replacement, Button Panel: passo 1, imagem 2 %32 Instant Pot 60 EPC Button Panel Replacement, Button Panel: passo 1, imagem 3 %32
    • Ensure the device is unplugged and cool before beginning.
    • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
    • Remove the single Torx screw.
  2. Instant Pot 60 EPC Button Panel Replacement: passo 2, imagem 1 %32 Instant Pot 60 EPC Button Panel Replacement: passo 2, imagem 2 %32
    • Turn the bottom face counterclockwise and remove it.
  3. Instant Pot 60 EPC Button Panel Replacement: passo 3, imagem 1 %32 Instant Pot 60 EPC Button Panel Replacement: passo 3, imagem 2 %32
    • In order to reach the circuit board you'll need to remove the secondary frame surrounding it.
    • Remove the three Phillips screws securing the frame.
    • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
  4. Instant Pot 60 EPC Button Panel Replacement: passo 4, imagem 1 %32 Instant Pot 60 EPC Button Panel Replacement: passo 4, imagem 2 %32
    • Disconnect the 8x1 pin control connector from the main board.
    • The plug should easily come up when pulled with slight pressure.
    • It may be helpful to also rock the plug side to side while pulling up.
  5. Instant Pot 60 EPC Button Panel Replacement: passo 5, imagem 1 %32
    • Remove the single screw attaching the front panel to the main body with a Phillips screwdriver.
    • This screw may be difficult to get to; we were able to remove it by threading a screwdriver underneath the main board.
  6. Instant Pot 60 EPC Button Panel Replacement: passo 6, imagem 1 %32 Instant Pot 60 EPC Button Panel Replacement: passo 6, imagem 2 %32 Instant Pot 60 EPC Button Panel Replacement: passo 6, imagem 3 %32
    • Remove the main body from the Instant Pot.
    • It should easily pull up with a little force and be free from the control board.
  7. Instant Pot 60 EPC Button Panel Replacement: passo 7, imagem 1 %32 Instant Pot 60 EPC Button Panel Replacement: passo 7, imagem 2 %32
    • Remove the Phillips screw.
  8. Instant Pot 60 EPC Button Panel Replacement: passo 8, imagem 1 %32 Instant Pot 60 EPC Button Panel Replacement: passo 8, imagem 2 %32
    • Pull the front panel away from the body and carefully pull out the wires that connect the front panel to the circuit board.
    • The front panel is now free to be replaced.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 148
