Ir para o conteúdo principal
Installing Sewing Machine Bobbin
Brittany McCrigler
Brittany McCrigler e 4 outros colaboradores
Última atualização em January 28, 2025
5 minutos
Fácil
Patagonia
Introdução
Ir para o passo 1
A bobbin is a small spool of thread that feeds the thread for the backside of the stitch. No sewing machine can sew without one. An incorrectly set up bobbin will create tangles in the thread. Bobbin setups vary from machine to machine. This guide shows the process for a Bernina 830, but the process will be similar for most sewing machines, except for those with drop-in bobbins. Refer to your sewing machine’s owner’s manual for specific directions on how to install a bobbin in your machine.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Installing Sewing Machine Bobbin, Installing Sewing Machine Bobbin: passo 1, imagem 1 %32 Installing Sewing Machine Bobbin, Installing Sewing Machine Bobbin: passo 1, imagem 2 %32
    • Use your finger to open the bobbin door below the presser foot.
  2. Installing Sewing Machine Bobbin: passo 2, imagem 1 %32 Installing Sewing Machine Bobbin: passo 2, imagem 2 %32
    • Align the hole in the bobbin spindle over the peg in the bobbin case.
    • Slide the bobbin into the bobbin case, leaving a bit of thread outside the case.
    • Take the loose thread end and slide it through the slit on the side of the bobbin case.
    So do you have the thread coming out to the right like the photo or to the left ?
    Rebecca Petts - Responder
  3. Installing Sewing Machine Bobbin: passo 3, imagem 1 %32 Installing Sewing Machine Bobbin: passo 3, imagem 2 %32
    • Slide the thread from the slit straight up along the groove and into the open hole on the bobbin case's side.
  4. Installing Sewing Machine Bobbin: passo 4, imagem 1 %32 Installing Sewing Machine Bobbin: passo 4, imagem 2 %32
    • Keeping the bobbin in place, turn the bobbin case so that the back is facing you.
    • Use your fingernail to lift the lever on the back of the bobbin case. Hold the lever open.
  5. Installing Sewing Machine Bobbin: passo 5, imagem 1 %32 Installing Sewing Machine Bobbin: passo 5, imagem 2 %32
    • Holding the bobbin case lever open, insert the bobbin case into the cavity under the presser foot.
    • Align the metal arm on the bobbin case so that it sits in the slot in the machine.
    • Release the bobbin case.
  6. Installing Sewing Machine Bobbin: passo 6, imagem 1 %32 Installing Sewing Machine Bobbin: passo 6, imagem 2 %32
    • Close the door on the compartment below the presser foot.
    You should leave a tail of thread sticking out of the compartment door. This creates tension and allows the bobbin thread to be pulled up correctly to the sewing surface. Once the bobbin thread is 'up', then you can put the table back in place.
    jodyvalerie - Responder
Linha de Chegada
6 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.977 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
120 Membros
Autoria de 20.002 guias
1Comentário do guia
Love it! Thank you for posting this as my wife has had to fix things on her sewing machine and it's good to have a reference other than Youtube where you can sit down and read it and make adjustments accordingly!
Alex - Responder
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 53
Últimos 30 dias: 272
Ao todo: 54,757
