Ir para o conteúdo principal
Inner Frame
Inner Frame
Joe Kendall
Joe Kendall e 2 outros colaboradores
Última atualização em September 10, 2019
5 minutos
Moderado
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
Introdução
Ir para o passo 1
In order to access the core components of the Acer Aspire One 725-0845, you will need to remove the inner frame, detailed here.
O que você precisa
Ferramentas
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
Exibir mais…
  1. Inner Frame, Battery: passo 1, imagem 1 %32
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Inner Frame: passo 2, imagem 1 %32 Inner Frame: passo 2, imagem 2 %32 Inner Frame: passo 2, imagem 3 %32
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Inner Frame, Back Plate: passo 3, imagem 1 %32 Inner Frame, Back Plate: passo 3, imagem 2 %32 Inner Frame, Back Plate: passo 3, imagem 3 %32
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Inner Frame, Hard Drive: passo 4, imagem 1 %32 Inner Frame, Hard Drive: passo 4, imagem 2 %32
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
  5. Inner Frame: passo 5, imagem 1 %32
    • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
    • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
  6. Inner Frame, Inner Frame: passo 6, imagem 1 %32 Inner Frame, Inner Frame: passo 6, imagem 2 %32 Inner Frame, Inner Frame: passo 6, imagem 3 %32
    • Using the JIS J1 Screwdriver Bit and Driver, remove the six outside screws (7.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the seven inside screws (8.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the one inside screw (3.0 mm).
  7. Inner Frame: passo 7, imagem 1 %32 Inner Frame: passo 7, imagem 2 %32 Inner Frame: passo 7, imagem 3 %32
    • Using your hands, slide the brown release tabs for the keyboard connection away from the center of the device.
    • Gently remove the keyboard connection by pulling away from the center of the device.
    • Lift the black locks for the touchpad connections into the upward position.
    • Gently remove the touchpad connections by pulling the purple tabs away from the locks.
  8. Inner Frame: passo 8, imagem 1 %32 Inner Frame: passo 8, imagem 2 %32 Inner Frame: passo 8, imagem 3 %32
    • Flip the device over and open it.
    • Using the plastic opening tools, remove the cover/palm rest from the frame of the device.
Conclusão
Uma outra pessoa concluiu este guia.
Joe Kendall
Membro desde: 02/15/17
346 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 8-3, Eyestone Spring 2017 Membro de USF Tampa, Team 8-3, Eyestone Spring 2017
USFT-EYESTONE-S17S8G3
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 18
Ao todo: 56
