Ir para o conteúdo principal
IBM ThinkPad T42 Keyboard and Trackpad Replacement
Austin Kidd
Austin Kidd e 7 outros colaboradores
Última atualização em January 10, 2025
10 - 15 minutos
Moderado
Precisa de melhores imagens
Faltando Passos
Melhor Introdução
O que você precisa
Ferramentas
  1. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Bottom cover: passo 1, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Rear screws: passo 2, imagem 1 %32
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Keyboard and Trackpad: passo 3, imagem 1 %32
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Keyboard and Trackpad Replacement: passo 4, imagem 1 %32 IBM ThinkPad T42 Keyboard and Trackpad Replacement: passo 4, imagem 2 %32
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
Conclusão
3 outras pessoas executaram este guia.
Austin Kidd
Membro desde: 04/21/10
317 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 29-76, Johann Spring 2010 Membro de Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Membros
Autoria de 37 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 18
Ao todo: 10,177
