Ir para o conteúdo principal
IBM ThinkPad T42 Fan Replacement
Kevin Rehm
Kevin Rehm e 10 outros colaboradores
Última atualização em January 2, 2024
5 - 10 minutos
Moderado
Precisa de melhores imagens
Faltando Passos
Ferramentas incorretas
Introdução
Ir para o passo 1
Use this guide to replace a fan for an IBM ThinkPad (Model T42). If your computer is making excessive noises, sounds louder than usual, or feels hot to the touch, the fan may need to be replaced. The fans' purpose is to pull cooler air into the computer to cool the hot circuitry. A failing fan can cause your laptop to sound louder because it is working harder than it normally needs to. Prior to using this guide, ensure nothing is blocking the fan or is in the way of the flow of the fan. A quick cleaning of debris or built-up dirt with a microfiber cloth may improve the functionality of the fan. If the fan is still dysfunctional, the next step would be to move forward with replacing the fan. Before beginning the process of replacing the fan make sure that your device is fully turned off and disconnected from any external power sources.
O que você precisa
Ferramentas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. IBM ThinkPad T42 Fan Replacement, Bottom cover: passo 1, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Fan Replacement, Rear screws: passo 2, imagem 1 %32
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
    leave these four screws alone. No need to remove them.
    fredwb - Responder
    There are tiny numbers showing the lengths of the screws. 1-2-3-4 where 1 is the shortest.
    The dark red circles are not very easy to see. How about white ones?
    mattikaki - Responder
  3. IBM ThinkPad T42 Fan Replacement, Keyboard and Trackpad: passo 3, imagem 1 %32
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Fan Replacement: passo 4, imagem 1 %32 IBM ThinkPad T42 Fan Replacement: passo 4, imagem 2 %32
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: passo 5, imagem 1 %32 IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: passo 5, imagem 2 %32
    • Starting from the bottom right, carefully remove the bezel by pulling it up gently. If needed use a spudger or flathead screwdriver to help.
  6. IBM ThinkPad T42 Fan Replacement, Lower Bracket: passo 6, imagem 1 %32 IBM ThinkPad T42 Fan Replacement, Lower Bracket: passo 6, imagem 2 %32
    • Grasp the metal bracket to remove it from the device.
  7. IBM ThinkPad T42 Fan Replacement, Microphone cover: passo 7, imagem 1 %32
    • Remove the rubber cover from the microphone.
  8. IBM ThinkPad T42 Fan Replacement, Fan Removal: passo 8, imagem 1 %32 IBM ThinkPad T42 Fan Replacement, Fan Removal: passo 8, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove the three screws on the copper heatsink.
    • Separate the copper heatsink by pulling it upwards, in order to unplug the connector from the motherboard.
    • Due to the nature of old thermal paste, it might take some force to remove the heatsink.
Conclusão
8 outras pessoas executaram este guia.
Kevin Rehm
Membro desde: 04/19/10
472 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 29-76, Johann Spring 2010 Membro de Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Membros
Autoria de 37 guias
2Comentários do guia
How about you just down the freely available Hardware Maintenance Manual (HMM) for the laptop. They are downloadable in PDF format, and very well done.
Martin Campbell - Responder
It doesnt take this much, if you remove the palm rest and keyboard you can get it at an angle it slides straight out.
Tobyn Genn - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 26,639
