Ir para o conteúdo principal
HyperX Alloy Origins Key Switch LED Replacement
Adam Sles
Adam Sles e 2 outros colaboradores
Última atualização em April 9, 2023
30 minutos - 1 hora
Difícil
Introdução
Ir para o passo 1
This guide will show how to replace the mechanical key switch LEDs from your HyperX Alloy Origins mechanical keyboard (serial number HX-KB6RDX and its variants).
The HyperX Alloy Origins mechanical keyboard provides RGB lighting to each of its keys through switch-mounted LEDs. Therefore, it is necessary to remove an entire key switch whenever its corresponding LED needs to be replaced.
Before beginning LED replacement, be sure to visit the troubleshooting page before making permanent changes to the PCB! This guide should only be used in the event that one or more keys do not light up while the remaining key LEDs are properly functioning.
Usage of a desoldering iron or a desoldering pump (alongside a normal soldering iron) is strongly recommended. The HyperX key switches contain pins which make it difficult to wick away solder. This guide uses a sole soldering iron for demonstration purposes only.
O que você precisa
Ferramentas
Exibir mais…
  1. HyperX Alloy Origins Key Switch LED Replacement, Toggle Indicator Tab: passo 1, imagem 1 %32
    • Locate the toggle indicator tab on the top right corner of the keyboard.
  2. HyperX Alloy Origins Key Switch LED Replacement: passo 2, imagem 1 %32 HyperX Alloy Origins Key Switch LED Replacement: passo 2, imagem 2 %32
    • Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
    • Lift up gently on the tab, while holding the left side of the tab down.
    • The tab can spring upwards upon removal. Eye protection is recommended during this step.
  3. HyperX Alloy Origins Key Switch LED Replacement, Backplate: passo 3, imagem 1 %32 HyperX Alloy Origins Key Switch LED Replacement, Backplate: passo 3, imagem 2 %32
    • Flip the keyboard over so that the backplate is facing you.
  4. HyperX Alloy Origins Key Switch LED Replacement: passo 4, imagem 1 %32 HyperX Alloy Origins Key Switch LED Replacement: passo 4, imagem 2 %32 HyperX Alloy Origins Key Switch LED Replacement: passo 4, imagem 3 %32
    • Remove the rubber feet on the four corners of the backplate.
    • When reassembling, use an adhesive to reattach the feet. A silicone rubber adhesive is recommended.
  5. HyperX Alloy Origins Key Switch LED Replacement: passo 5, imagem 1 %32 HyperX Alloy Origins Key Switch LED Replacement: passo 5, imagem 2 %32 HyperX Alloy Origins Key Switch LED Replacement: passo 5, imagem 3 %32
    • Remove the specified keycaps as depicted in the image.
  6. HyperX Alloy Origins Key Switch LED Replacement: passo 6, imagem 1 %32 HyperX Alloy Origins Key Switch LED Replacement: passo 6, imagem 2 %32 HyperX Alloy Origins Key Switch LED Replacement: passo 6, imagem 3 %32
    • Remove all Philips #0 screws from the new openings created after removing the rubber feet and plastic tab.
  7. HyperX Alloy Origins Key Switch LED Replacement: passo 7, imagem 1 %32 HyperX Alloy Origins Key Switch LED Replacement: passo 7, imagem 2 %32 HyperX Alloy Origins Key Switch LED Replacement: passo 7, imagem 3 %32
    • Separate the backplate from the keyboard using your hands.
  8. HyperX Alloy Origins Key Switch LED Replacement, Key Switch: passo 8, imagem 1 %32 HyperX Alloy Origins Key Switch LED Replacement, Key Switch: passo 8, imagem 2 %32 HyperX Alloy Origins Key Switch LED Replacement, Key Switch: passo 8, imagem 3 %32
    • Identify the key switch to be replaced.
    • Remove its keycap by carefully prying it off of the keyboard with your fingers.
  9. HyperX Alloy Origins Key Switch LED Replacement: passo 9, imagem 1 %32 HyperX Alloy Origins Key Switch LED Replacement: passo 9, imagem 2 %32
    • Flip the keyboard over to face the PCB.
    • Identify the corresponding switch to be removed.
  10. HyperX Alloy Origins Key Switch LED Replacement: passo 10, imagem 1 %32
    • Plug in and turn on your soldering iron.
    • Do not touch the metal end of the soldering iron while it is powered on. Allow the soldering iron to cool before stowing it away.
  11. HyperX Alloy Origins Key Switch LED Replacement: passo 11, imagem 1 %32 HyperX Alloy Origins Key Switch LED Replacement: passo 11, imagem 2 %32 HyperX Alloy Origins Key Switch LED Replacement: passo 11, imagem 3 %32
    Ferramenta utilizada neste passo:
    Desoldering Pump
    $3.99
    • Melt the solder surrounding the four pins of the switch's LED, and the two lower pins of the switch body.
    • To remove the melted solder, use a desoldering iron, a desoldering pump, or desoldering braid.
    • The exposed switch pins are susceptible to damage from the soldering iron. Avoid applying heavy pressure to mitigate pin bending.
  12. HyperX Alloy Origins Key Switch LED Replacement: passo 12, imagem 1 %32
    • Using a spudger or another metallic instrument, firmly press down upon the exposed plastic of the switch. This will separate the switch from the rest of the keyboard.
    • If the switch's pins will not separate from the keyboard's PCB, continue applying the soldering iron to the pins to melt any residual solder.
  13. HyperX Alloy Origins Key Switch LED Replacement, Key Switch LED: passo 13, imagem 1 %32
    • Gently pull the LED off of the switch.
    • Do not break the LED pins while it is still attached to the switch.
Conclusão
To reassemble your device, follow these instructions in reverse order. Note that when reattaching the switch back to the keyboard PCB, the switch needs to be held in place behind the keyboard while soldering.
Adam Sles
Membro desde: 10/25/22
289 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 5-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G2
5 Membros
Autoria de 15 guias
2Comentários do guia
Hola, muy buena guía.. quizá no lo vi mencionado, pero que modelo? Nombre, tiene el LED en especifico.
Quiero conseguir el repuesto ya que tengo un led que no enciende el color verde. Entonces quería cambiarlo
Juan Perez - Responder
Hola buenas noches tengo el teclado hyperx alloy origins alguien ha tenido problema que al guardar una configuracion de colores bien sea en F1, F2, F3 el teclado deja de funcionar y se demora alrededor de 1 hora en guardar la configuracion? aproposito el teclado funcionaba normalmente pero un dia el rgb no volvio a encender y en el software Ngenuity se ve el efecto Wave activo.
ya he usado la tecla FN + ESC . ALT IZQ + ESPACIADORA + FN , he reinstalado Ngenuity, he probado en otro pc pero la situacion sigue igual. si alguien me puede ayudar le estaria agradecido.
Wilder Hernandez Castro - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 89
Ao todo: 5,065
