Huawei Mate 20 Pro Battery Disconnect Procedure
Introdução
Ir para o passo 1prereq battery disconnect
O que você precisa
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
Insert a fourth opening pick under the top left corner of the back cover.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Remove the eight Phillips #00 screws (4.3 mm length).
