Ir para o conteúdo principal
How to put an iPhone into Recovery Mode
Duckida
Duckida e 4 outros colaboradores
Última atualização em 3 de ago de 2024
5 - 35 minutos
Muito fácil
Guia colaborativo
Introdução
Ir para o passo 1
You may need to use recovery mode to restore your device in the following situations:
  • You forgot your passcode or your phone is disabled.
  • Your screen is stuck on the Apple logo for several minutes with no progress bar.
  • Your phone is bootlooping.
Note: If you forgot your passcode, you will have to erase the device.
Vídeo de Apresentação
  1. How to put an iPhone into Recovery Mode, Connect to a Computer: passo 1, imagem 1 %32
    • Using a Lightning or USB-C cable, connect your iPhone to a Mac or PC. If you’re using macOS Mojave or earlier, or a PC, install iTunes.
  2. How to put an iPhone into Recovery Mode, Button Combination Press: passo 2, imagem 1 %32
    • If you have an iPhone 8 or later: press and release the Volume Up button, press and release the Volume Down button, press and hold the Side button until you see the Recovery Mode screen
    • For an iPhone 7 or 7 Plus: Press and hold the Side button and Volume Down button until you see the Recovery Mode screen.
    • On iPhone 6s or earlier: Press and hold both the Power button and the Home button until you see the Recovery Mode screen.
    the problem is that this is not working for my iphone 8, i keep doing it over and over again and it just doesn't go into recovery it only reboots.
    annoyedasf - Responder
  3. How to put an iPhone into Recovery Mode, Recover the device: passo 3, imagem 1 %32 How to put an iPhone into Recovery Mode, Recover the device: passo 3, imagem 2 %32
    • For macOS Catalina and Later: Open Finder. In the sidebar, you will see your device. When you click on it, a pop up will appear prompting for Update or Restore. Update will reinstall the OS without erasing data. If the update option fails or you are locked out of your device, restore will reinstall the OS and erase all data.
    • For macOS Mojave and Prior or Windows: Open iTunes. In the top left corner will be an icon for the iPhone. When you click it, a popup will appear prompting to Update or Restore. Update to reinstall the OS without erasing data. If the update option fails or you are locked out of your device, restore will reinstall the OS and erase all data.
    I’ve transferred the eSIMs data plan or phone number on my iPhone 15
    Grant Lewis - Responder
Conclusão
To put your iOS device in recovery mode, follow these instructions. You will need a Mac or a PC with iTunes.
74 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Duckida
Membro desde: 02/07/20
2.075 Reputação
Autoria de 1 guia
9Comentários do guia
My power button is not working on an iphone 6, so I can't use these directions! Do you have a work around for this situation?
Thanks
Jeff
Jeff Lawton - Responder
On iPhone 6, the power button is really only necessary to turn the device off. You can also accomplish this by disconnecting the battery. Which isn't ideal, but it's better than not being able to do it at all. After it's off, reconnect the battery, then hold down the home button and connect the lightning cable from the USB cable to your computer.
Alisha C -
Some repair tools can get the device into or out of Recovery Mode without pressing buttons physically. TunesKit iOS System Recovery has this feature for totally free, you can use this to put your iPhone into Recovery Mode without any limits.
pony King -
My home button is not functioning, so even if I disconnect the battery and reconnect it, I will be at the same place. I had to use the digital home button to use the phone before it got disabled. It's that white circular digital button that can be used as an alternative when the physical home key is not functioning.
My phone just suddenly off by itself an iPhone 12 Pro Max please I don’t know what to do
Amadi Divine - Responder
I replaced the screen and back glass on iphone 14 and now every few mins it reboots? Why is this? i would really appreciate some resolutions
Tim - Responder
On the iPhone 14 and 14 Plus there is a flex cable on the back glass that contains a part that contain a sensor that is likely paired to the phone. So if you replace the back glass, that flex cable may need to be transplanted to the new back glass for everything to work properly. Jason at STS Telecom did a super video that explains some off this.
Alisha C -
How can I remove the recovery mode of iPhone SE
Sandra Belle - Responder
Like, it's stuck in recovery mode?
Alisha C -
Comentar
Visualizações:
Últimas 24 horas: 126
Últimos 7 dias: 1,245
Últimos 30 dias: 5,175
Ao todo: 143,558
