Ir para o conteúdo principal
How to make Dyson AM07 (more) useable!
Frank
Frank e um outro colaborador
Última atualização em August 11, 2024
2 - 5 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
The remote control for the Dyson AM07 (and possibly other Dyson fans and heaters - I only own the AM07, so I don't know) has a sleek design, but unfortunately it's a case of "function follows form".
Without looking at it, you can't tell where the buttons are and what they do because they are flush with the rest of the thing. Which makes this remote not very useable, especially at night.
Luckily, there's a very easy (and reversible) fix for this. All you need is a glue gun! :)
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to make Dyson AM07 (more) useable!, Overview and button names: passo 1, imagem 1 %32
  2. How to make Dyson AM07 (more) useable!, Add some dots!: passo 2, imagem 1 %32 How to make Dyson AM07 (more) useable!, Add some dots!: passo 2, imagem 2 %32
    • Plug in your glue gun and let it heat up.
    • I made a big dot on the oscillation button, another one on the Standby ON/OFF button, and two more dots (big and small) on the Airflow control buttons. I don't use the Sleep Timer so I haven't added any dots to those two buttons.
    • If you don't get it right on the first try, don't worry. Just wait a couple of seconds for the glue to cool down and remove the dot. The glue comes off without leaving any residue or marks on the plastic.
  3. How to make Dyson AM07 (more) useable!, Bonus points: make shapes: passo 3, imagem 1 %32 How to make Dyson AM07 (more) useable!, Bonus points: make shapes: passo 3, imagem 2 %32
    • I used a carpet cutter (sharpest knife I had lying around) to cut the dot on the Standby ON/OFF button into an "I" shape for a little bit of different tactile feedback.
    • Some more ideas for customization: while the glue is still fluid, stick little parts of plastic, for example, in it to get different kind of buttons.
    Simple, cheap and creative idea: wonderful!
    But indeed, not for people who store the remote on top of the fan.
    Axello - Responder
  4. How to make Dyson AM07 (more) useable!, The result: passo 4, imagem 1 %32 How to make Dyson AM07 (more) useable!, The result: passo 4, imagem 2 %32 How to make Dyson AM07 (more) useable!, The result: passo 4, imagem 3 %32
    • They could look better but the buttons are a lot more useable now, in my opinion.
    Geh bitte was soll das?????????????????????????????????????
    Orval denafunk - Responder
Conclusão
To undo these changes and restore your remote, just peel off the dots.
4 outras pessoas executaram este guia.
Frank
Membro desde: 06/08/15
85 Reputação
Autoria de 1 guia
4Comentários do guia
I would not recommend this. I would just order custom buttons and use some 3m tape to attach to the remote. Also, I don't have any problems finding the right buttons in the dark to control my fan.
kayshawncartel - Responder
Good for you. Then just ignore this guide.
Frank -
Bit a crap mod me thinks… not well thought out… its pretty obvious that if you do this the control will no longer sit nicely on top of the fan! Better off learning your left from your right ;-)
Abdullah Khan - Responder
Useful, but not sure about the appearance.
I’m interested in how to alter a Dyson Hot & Cold fan bought in the UK for use in the US…if anyone has recommendations?
James Bowkett - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 50
Ao todo: 13,920
