Ir para o conteúdo principal
How to create a ChromeOS Recovery USB Drive
O que você precisa
      • In order to make your recovery device, you will need the following items.
      • 1 x USB Drive or SD Card (8 GB is the minimum)
      • Any content that is stored on this drive will be erased during the next few steps. Be sure to back up any content you want saved, or make sure this is a drive you are going to use for future devices.
      • 1 x computer running the Google Chrome Browser, or Chrome OS.
      Pergunte ao FixBot
      Comentar
    1. How to create a ChromeOS Recovery USB Drive, Download the Recovery Utility: passo 2, imagem 1 %32 How to create a ChromeOS Recovery USB Drive, Download the Recovery Utility: passo 2, imagem 2 %32
      • Open Google Chrome and navigate to the Chrome Web Store and download the Chromebook Recovery Utility extension.
      • Add the utility to Chrome and launch it. You will be greeted with this page.
      Pergunte ao FixBot
      Comentar
    2. How to create a ChromeOS Recovery USB Drive, Enter your Chromebook Model Number: passo 3, imagem 1 %32
      • Click on "Get started" and you will be prompted to enter the model of your Chromebook.
      • You have the option of either entering the code that is on the device's recovery screen, or choosing from the model list.
      Pergunte ao FixBot
      Comentar
    3. How to create a ChromeOS Recovery USB Drive, Insert your Removable Media: passo 4, imagem 1 %32
      • Plug in your spare 8 GB USB Drive and select it from the dropdown menu.
      • Any content that is stored on the drive will be erased during the next few steps. Make sure that the drive is empty, or does not have any data that you don't want to lose.
      Pergunte ao FixBot
      Comentar
    4. How to create a ChromeOS Recovery USB Drive, Create Recovery Image: passo 5, imagem 1 %32
      • You will be presented with a screen that shows the drive you selected. Click on the "Create now" button and the processes will begin.
      • Do not remove the drive while the process is taking place. The process will take about 5 minutes to complete and you will be prompted when the recovery drive is finished.
      Pergunte ao FixBot
      Comentar
Conclusão
If you intend on reusing the drive for storing files you will need to use the Recover Utility application to erase the data on the drive, and you will need to reformat it with a recovery tool.
101 outras pessoas executaram este guia.
Jacob Mehnert
Membro desde: 10/18/21
49.341 Reputação
Autoria de 51 guias
Equipe
iFanatics Membro de iFanatics
Community
69 Membros
Autoria de 382 guias
15Comentários do guia
Thanks only this is working all the other instructions on google didnt work… Direct and simple instructions
idide akeh - Responder Compartilhar
I'm glad to hear that this guide helped you out!
Jacob Mehnert - Responder Compartilhar
Hello....I followed all you said here yet my USB flash drives got corrupted after the recovery utility completed
Amos - Responder Compartilhar
Hello, you might need to wipe the USB drive and attempt to install the recovery tool again. You might also want to check that the drive is formatted to FAT32. Other formats have been known to cause errors with the recovery tool.
Does it matter if it’s a 2.0 or 3.0 USB drive???
Josh Knapp - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 20
Últimos 7 dias: 105
Últimos 30 dias: 552
Ao todo: 59,582
